06-22-2008, 08:57 AM | #1 |
Transfer case questions
Well, I put in the transfer case yesterday, by myself I might add! I add that because I could have killed myself! It really helps to have the right tools to do this job, which I don't but I got it done with the help of a cherry picker and floor jack that I decided I had better go get before I broke major bones! The books I got were hard to find the specs on the torques and the descriptions were not what I expected. I will describe what I did and you all can tell me if I am OK. The bracket the attaches to the trany that also has two holes for the transmission support I tightened them to 130 ft/lbs and the small L bracket on the pass side of the frame attached with rubber grommets I attached at 130 also. The major mount at the bottom I mentioned first had the rubber transmission mounts that I had failed to mention. Does that sound OK or are you all confused? Next project is drive shafts the motor and tranny!
06-22-2008, 09:27 AM | #2 |
Post Whore
Re: Transfer case questions
Those are pretty sizeable bolts so I'm sure your fine. I'm positive the torque was higher than 90 ft/lbs, but I don't remember the exact amount.
1970 Blazer with a 400 sbc and 4" lift 1980 Pontiac Trans Am, 455 Oldsmobile 2012 Kawasaki Concours 14 |
06-22-2008, 11:15 AM | #3 |
From the service manual specifications..
TC to frame bolts 130 ft-lb Adapter mount bolts 75 ft-lb TC bracket to Frame nuts (upper) 30 ft-lb TC bracket to Frame nuts (lower) 65 ft-lb This is for an NP205. |
06-22-2008, 03:49 PM | #4 |
where can i get a copy of the service manual you are reading out of
06-23-2008, 01:39 AM | #5 |
06-23-2008, 08:40 AM | #6 |
I read the same info but just wanted to have someone say that looks OK. Thanks!
