06-22-2008, 09:04 AM | #1 |
454 MAKES IT ROAR
Video...please take a look.
OK, just outside now on a lovely sunny Sunday changing the gasket on my Trans pan...never done this before and never seen inside one of these before so when I saw this thing hanging loose I paniced. Should it be loose or is there something badly wrong?.
Thanks in advance.
Nigel. An American living in a British body. 1971 Chevy Cheyenne 10 454 "In a time of universal deceit, telling the truth becomes a revolutionary act." - George Orwell "When injustice becomes law, resistance becomes duty" - Thomas Jefferson No more pain. 03.12.60 -- 12.28.10 http://www.youtube.com/Eightbanger |
06-22-2008, 09:59 AM | #2 |
Re: Video...please take a look.
I don't know how much filter function you are losing, but it definitely isn't doing much good that way.
Kelly '05 GMC Sierra SLE Z71 Bone stock except for new bed rail caps. |
06-22-2008, 10:09 AM | #3 |
Should be held in place snug by the bolt it's rattling around on. You are going to replace it ain't ya?
LIFE AIN'T EASY WHEN YER FAT AND GREASY! GMC= Got More Class! 1970 GMC LWB, Fleetside, 350/4spd, Flowmaster "40's", 2002 GMC 16" Rallies, cowl hood,and added a bunch of options that weren't there when I started. |
06-22-2008, 10:54 AM | #4 |
just replace the filter you'll be fine
David fuller Ase Certified Mechanic Click here to help support our board!! 1971 Chevy c-10 under going a 4.8l LSx swap Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=421305 2007 Honda Accord my daily 145kmiles 2002 Honda Accord 4 door With 330k(sisters car) 2005 toyota Avalon 228k( brothers car) 2002 Sububran 5.3 245k 2000 Tahoe 5.3l 378 General manager for Marco's Carwash & lube |
06-22-2008, 10:54 AM | #5 |
Trucks N Tranzams
Eightbanger,
Your filter is ok like that. It will work just fine. It is missing the special shouldered bolt that often gets lost during transmission filter changes. You can make a sleeve for your existing bolt out of a small steel tube. Cut it just long enough to hold the filter level and tight without the pan in place. Tighten your existing bolt gently against the bottom of the new filter using a lock washer or locktite. The TH400 filter inlet is on the top of the filter not the bottom.
Don '68 Chevy LB 383 TH400/GV/373 posi '56 Chevy 4WD SWB '64 Chevy short stepside '79 Trans Am 455/TH2004R/12blt/4whldisc 95 Kia (Wifes car) 2002 S-10 extended cab pickup "God punishes small sins immediately" |
06-22-2008, 11:10 AM | #6 |
454 MAKES IT ROAR
The filter did look like it was ok but that's the first time i've seen it, I did'nt get a new filter so it will have to go back for now...Arad68 i'm gona go with what you have said the small bolt that is there does have a shoulder and only threaded part way down so seems to be the correct one, but still this did not look like it was right I will try to make up a small spacer for it now so thanks for your help, and to everyone else.
06-22-2008, 11:57 AM | #7 |
Trucks N Tranzams
No sweat dude! I was a little bent when I first saw this myself.
The TH400 has a great reputation as one of the most durable transmissions ever built. Don't let this bother you too much. It is still a great trans!!
06-22-2008, 12:04 PM | #8 |
Thats how they are soposed to be. The pickup tube that joins the filter to the trans might be a bit loose. The filter rests on the pan when its all togeather, so it doesn't flop around like that when the pan is on.
