master cylinder?
is the front bowl on the master cylinder for the front brakes or rear? i am asking for the simple fact that i think mine is backwards from the original owner. 72 disc front drum rear.
Re: master cylinder?
The 3/4 ton master cylinder is opposite from the 1/2 ton master cylinder. The 1/2 ton has the front reservoir for the front discs. The 3/4 has the rear reservoir for the front discs.
The 3/4 ton booster and reservoir can be used on the 1/2 ton trucks. Jim
1971 Shortbox step side 4x4, 350 sbc, 3:07 rear end 1965 Impala SS 400 sbc, Muncie rock crusher 1966 Impala SS 396 bbc, TH 400 1969 El Camino, 350 sbc, TH 350 1971 Snowplow built on a Blazer frame 1972 GMC Short bed, stepside, TH 400, 427 BBC Last edited by JimKshortstep4x4; 06-22-2008 at 01:11 PM. Reason: wording |
Another way to tell is to look at the size of each resevoir. The larger one is for the discs
thanks guys, the truck has an old style hydraulic trailer brake unit on it. just making sure what brakes i need to bleed after i remove it.
Get some new fluid and do them all so you can get rid of the old, black, chunky fluid that's in there now... Assuming you haven't been through the system yet.
