06-22-2008, 01:32 PM | #1 |
senior member
i need some thought and ideas for my bed please
well ever since i put in the c notches and the blocks under my axles now i have the problem of the rearend hitting the wood floor. Im sure i could just use shorted blocks or adjust the bump stops but i really like the stance my truck has now. What do you guys think of cutting out a small section for the diff to pop thru the few inches it might need? any one else have some ideas?
69 GMC bagged |
06-22-2008, 01:37 PM | #2 |
senior member
Re: i need some thought and ideas for my bed please
hes is a very crude interpretation of what i had in my mind, the blue part is where i thought id make a frame just so it doesnt look scabby and you see the cut wood?? P.S. that black blob is supposed to be my diff
69 GMC bagged Last edited by pissonNOS; 06-22-2008 at 01:38 PM. |
06-22-2008, 04:50 PM | #3 |
It's just a check engine lamp.
I've seen a few people do it that way. You could also raise the wood floor a few inches so you wouldn't have a hole in it. It all depends on what you like, and how far you are willing to go. Good luck. John
Active Inliner---bigchevy66 68 SWB Stepside 250 L6/3 on the floor/ Hedman headers, HEI, MSD 6A box, K&N filter, Offy intake and Edelbrock 600cfm 4 barrel Soon to have: WC T-5 five speed 66 SWB Stepside-undergoing restoration |
06-23-2008, 12:13 AM | #4 |
Registered Mail
i plan on fabbing a sheet metal piece to go from wheel well the wheel well.. but then again my wells will be closer because of tubbing, but just a thought of a clean install.?
'67 chev 496, lwb to swb, bagged - pro street project |
06-23-2008, 12:27 AM | #5 |
Here is what this person did. Looked nice when i saw it. You could do something slightly smaller also.
Josh
(Project truck) 1970 C10 under complete transformation My current build thread http://67-72chevytrucks.com/vboard/s...d.php?t=212871 Other project: C5 corvette swap into 70 c10 http://67-72chevytrucks.com/vboard/s...=1#post2413517 On Hold |
06-23-2008, 02:30 PM | #6 |
senior member
thats what i was thinking but like you said on a smalle sscale
69 GMC bagged |
