Old 06-22-2008, 03:07 PM   #1
oldsmobilekindofguy
Crossmember question
I cut the crossmember in order to get my engine and tranny in, I have a 350 connected to a SM465 tranny I got it all in place and can be bolted in, but my only concern is the crossmember being strong enough. I took some pics to clarify things, I think it should be fine.
1967 c-10 longbox project, check it out in projects
1969 c-10 parts pickup, twisted frame
Daily driver- 1970 Olds delta 88, 2dr., 455, gotta love the big block
oldsmobilekindofguy is offline   Reply With Quote
Old 06-22-2008, 03:10 PM   #2
caminokid
Chevy nut
caminokid's Avatar
Re: Crossmember question
I think you better weld the middle back to it. I dont know if it being in two pieces that it will hold up.
84 Chevy Custom Deluxe 1/2 Ton Named Fade To Black II
"Remember kids there is NO replacement for displacement!"
caminokid is offline   Reply With Quote
Old 06-22-2008, 03:11 PM   #3
oldsmobilekindofguy
I would like to leave it as is so I can take the motor in and out with ease, so I would rather not brace it across again but I could make braces from the frame to the existing crossmember, that is if it needs to be braced?
Old 06-22-2008, 03:15 PM   #4
caminokid
Chevy nut
caminokid's Avatar
That would be a good idea too. I have my crossmember ready for bolts so I can take the whole thing out.
Old 06-22-2008, 03:21 PM   #5
oldsmobilekindofguy
thanks kid, any other input would be appreciated
Old 06-22-2008, 03:21 PM   #6
old Chevy guy
old Chevy guy's Avatar
Id worry there would be a lot of streess on the mounts,seems like those loose ends would want to twist up and down when the motor trys to twist.Mabey you could weld a flat plate on the bottem of each side of the piece you cut out ,then drill holes in the parts atached to the frame and bolt it in so you could remove it again if thats what you want.
old Chevy guy is offline   Reply With Quote
Old 06-22-2008, 10:47 PM   #7
oldsmobilekindofguy
thanks guy but if I do that there is clearance issues, even if I make it so I can unbolt the middle with the middle in there I can't get the dust cover on for ythe flywheel
Old 06-22-2008, 10:52 PM   #8
oldsmobilekindofguy
Does anyone have an idea of how I could brace up the two existing pieces so I don't have to put the middle back in
I kinda mutilated the piece in the middle by cutting it in three pieces anyway
Old 06-22-2008, 11:19 PM   #9
old Chevy guy
465 sm isnt that the big truck unit with the granny 1st? If so why is there a problem thats whats in my truck. What bell are you using,the one that bolts on the crossmember?How about just a flat plate across the bottom to tie it together will that still create a clearance problem?
Old 06-26-2008, 09:18 PM   #10
oldsmobilekindofguy
yes it is, and it does just bolt to the belhousing but It isn't original to the truck and I am trying to use the existing crossmember, It is also a low hump cab which created problems too, It was originally a three speed.
I decided to do pretty much your idea anyway, I am gonna weld plates down a couple inches and and bolt the middle across
Old 06-26-2008, 10:17 PM   #11
Sammy
Never seen a granny 4 spd in without a high hump cover. I doubt because of clearance issues that tranny would require a huge hole in the floor pan.
'69 Chevy Long Fleet & '71 GMC Short Step & Project "ODD BALL"
"You can wash a pig, soak it in most expensive perfume. In the end it is still just a pig."
ODD BALL build thread http://67-72chevytrucks.com/vboard/s...d.php?t=478629"
Sammy is offline   Reply With Quote
Old 06-26-2008, 11:08 PM   #12
oldsmobilekindofguy
you can see where the floor is cut out and it has to be cut out there that is not my problem, I am making the crossmember so I can pull the motor and trany in and out in one piece and I didn't want to put the middle back in but everyone on here and everyone I have talked to think I should so I am
Old 06-26-2008, 11:08 PM   #13
oldsmobilekindofguy
Thanks all for the input and help
