Old 06-22-2008, 03:26 PM   #1
gary67
brake pedal problem
i have a 71 i building i bought new master cyl new booster
the pedal will not come back up all the way by it self i have changed the spring do you think it could be the booster?
gary67 is offline   Reply With Quote
Old 06-22-2008, 04:08 PM   #2
68gmsee
Active Member
68gmsee's Avatar
Re: brake pedal problem
If your check valve and vacuum source are good, my guess is you have a defective booster. There's internal springs and check valves that my be preventing the pedal from returning to it's normal position.
Here's a site that's somewhat simplistic but best illustrates how the booster works.
http://auto.howstuffworks.com/power-brake2.htm
p.s. If you do a right mouse click on the pic you can zoom in and then drag the picture with the mouse and see the different functions closer up. If you right mouse click again on the pic you can click on play or zoom back out.
68gmsee is offline   Reply With Quote
Old 06-22-2008, 07:50 PM   #3
JimKshortstep4x4
Did you have a booster on the truck before? The pedal will be lower with power brakes.
Jim
1971 Shortbox step side 4x4, 350 sbc, 3:07 rear end
1965 Impala SS 400 sbc, Muncie rock crusher
1966 Impala SS 396 bbc, TH 400
1969 El Camino, 350 sbc, TH 350
1971 Snowplow built on a Blazer frame
1972 GMC Short bed, stepside, TH 400, 427 BBC
Old 06-22-2008, 08:45 PM   #4
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
the linkages between the booster and firewall can bind and cause this, as can a bum booster.
Old 06-22-2008, 09:10 PM   #5
68gmsee
Active Member
68gmsee's Avatar
Originally Posted by JimKshortstep4x4 View Post
Did you have a booster on the truck before? The pedal will be lower with power brakes. Jim
Yeah, I forgot to mention that part. If you converted from non power brakes, the pedal will be somewhat lower. I put power brakes on my 68 three on the column and the brake pedal with the link out as far as I dare lengthen it, is about one to one and a half inches below the clutch pedal...
