06-22-2008, 04:12 PM | #1 |
Manuel way to air up air bags?
I haven't ran my hard lines yet and i was curious if there was a way to air them shockwaves up without the air lines hooked up. Maybe a manuel way? I just want a back up plan incase i don't get the hard lines hooked up before hot august nights car show. Thanks
(Project truck) 1970 C10 under complete transformation My current build thread http://67-72chevytrucks.com/vboard/s...d.php?t=212871 Other project: C5 corvette swap into 70 c10 http://67-72chevytrucks.com/vboard/s...=1#post2413517 On Hold |
06-22-2008, 04:14 PM | #2 |
Re: Manuel way to air up air bags?
Is there room to just install schraders directly to the ShockWaves? Or you could remove the ShockWaves & install a solid piece of pipe the length needed for the ride height.
06-22-2008, 04:25 PM | #3 | |
Josh
06-22-2008, 06:18 PM | #4 | |
That would certianly get the job done but the ensuing visits to the doctor with back trouble might get a little old after a while.
Jim '71 Blazer-Porterbuilt Dropmember C4/LS1/6L80E '57 VW beetle - Oct. 2006 Hot VW's pg. 87 - 350hp intercooled, turbocharged, EFI 2.3liter and 5spd in the works '87 BMW 325i - daily driver |
06-22-2008, 08:33 PM | #5 |
He didn't say the plan was to actually drive it the whole weekend of the show .
06-22-2008, 09:06 PM | #6 | |
Josh
06-24-2008, 07:08 PM | #7 |
We sell some killer little stubby Schrader valves that have 1/4 NPT on the ends. They are even nickle plated for s clean looking finish. Let me know if you want some as you're only 2 days aways UPS ground, or I'd go USPS which is just as fast but cheaper.
http://www.kplinks.com/product.php?p...&cat=41&page=2
- Clint - Last edited by Kontrol Phreaks; 06-24-2008 at 07:08 PM. |
