Old 06-22-2008, 06:54 PM   #1
truckdude239
truckdude239's Avatar
what carb?
my reman 4 bbl qjet carb is not cutting it truck keeps flooding out i was thinking about an edelbrock somewhere around 500cfm its going on a 305
David fuller
Ase Certified Mechanic
Click here to help support our board!!
1971 Chevy c-10 under going a 4.8l LSx swap
Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=421305
2007 Honda Accord my daily 145kmiles
2002 Honda Accord 4 door With 330k(sisters car)
2005 toyota Avalon 228k( brothers car)
2002 Sububran 5.3 245k
2000 Tahoe 5.3l 378
General manager for Marco's Carwash & lube
truckdude239 is offline   Reply With Quote
Old 06-22-2008, 07:06 PM   #2
Billla
Billla's Avatar
Re: what carb?
I'd have a tendency to look at the fuel pressure and the float adjustment before giving up. I'm confident you can make what you have work...my $.02.
Billla is offline   Reply With Quote
Old 06-22-2008, 08:16 PM   #3
Bus Ted Knuckle
Son of a gun
Bus Ted Knuckle's Avatar
Re: what carb?
lower the float level.
It may just be some trash under the needle valve.
BEATERS ARE NEATER
Bus Ted Knuckle is offline   Reply With Quote
Old 06-22-2008, 08:47 PM   #4
truckdude239
Re: what carb?
how do i do that? carb is new fuel is clean going though filter
David fuller
2000 Tahoe 5.3l 378
Old 06-22-2008, 11:37 PM   #5
Bus Ted Knuckle
Son of a gun
Re: what carb?
in a nut shell...
Take the top off of the carb, hold gently on the needle, and GENTLY press down on the float.
There is a lot more to it then that...but the learning curve is steep. Do it once, and it'll be easy as pie after that.
Study the info in these links:
http://www.florida4x4.com/tech/quadr...d.com/Quad.htm
http://www.florida4x4.com/tech/quadrajet/qjtshoot.pdf
http://www.florida4x4.com/tech/quadrajet/qtune.pdf
BEATERS ARE NEATER
Old 06-23-2008, 09:14 AM   #6
Wrenchbender Ret
Re: what carb?
I agree.That carb should work & is the best carb. for that engine. Try this trick. If a piece of dirt got into the needle & seat this will clear it out.
Clamp a vice grip on the rubber fuel line to block the flow of gas. Start the engine & run it till it dies or almost dies. Remove the pliers & restart the engine. If it doesn't work the first time try it again. If it still doesn't work you will have to go into it like the guys said.
Wrenchbender Ret is offline   Reply With Quote
Old 06-23-2008, 09:48 AM   #7
Billla
Billla's Avatar
Re: what carb?
Talked a bit with him last night in chat - my recommendation was to get an overhaul kit and have a local shop replace the needle/seat and adjust the float.
Old 06-23-2008, 11:07 AM   #8
Wrenchbender Ret
Re: what carb?
Good advise Bill. He should try my tech tip first. I,ve saved many a carb doing that. Sometimes changing the filter will let a small particle get in the needle & seat. Sometimes these paper filters can give off a little fibre when new.
Old 06-23-2008, 04:50 PM   #9
truckdude239
Re: what carb?
advance is exchanging the carb for my it was 2 months out of warranty but they doing ti anyway
David fuller
2000 Tahoe 5.3l 378
Old 06-24-2008, 12:43 AM   #10
kingsolver72
10/30/19
kingsolver72's Avatar
Re: what carb?
Hey Dave,I've heard it that the reman carbs sit on the self awhile and the seals,gaskets dry out and it takes a couple of tries to get a fairly newer rebuilt carb.
Fight the good fight, finish the race, keep the faith
kingsolver72 is offline   Reply With Quote
Old 06-24-2008, 08:16 AM   #11
truckdude239
Re: what carb?
yeah i had the carb a year before i installed it it might have got roughed around once to yeah
David fuller
2000 Tahoe 5.3l 378
Old 06-24-2008, 09:08 AM   #12
Wrenchbender Ret
Re: what carb?
About half the rebuilt carbs you get from the part stores aren't any good.
Old 06-24-2008, 08:29 PM   #13
truckdude239
Re: what carb?
well the guy that tuned the the truck said when he adjusted the left screw it made a differenace and the right one did not mak nay differences
David fuller
2000 Tahoe 5.3l 378
