06-22-2008, 09:23 PM | #1 |
What rear end is this?
PO says its the original rear but the bolt pattern looks off from a GM 10 Bolt. Its under my 67 C20
SSG Jeffery Ahlheim 586th Network Support Company, 525th BfSB US Army, FT Bragg, NC 2009 Chevy Silverado LT ext cab 5.3L If you don't stand behind our troops, please feel free to stand in front of them. |
06-22-2008, 09:37 PM | #2 |
I have a radical idea!
Re: What rear end is this?
That's the correct Eaton HO52 for 3/4 tons. Its probably the stock rearend. That's a WHOLE lot more rearend than a regular 10 bolt. They are real strong, but gearsets are limited.
'67 C-30 Dually Pickup 6.2 Turbo Diesel, NP435 ‘72 C-10 SWB , 350 4bbl, TH350 '69 C-10 SWB , 250 L6, 3 OTT '69 GMC C3500, dump truck, 351 V6, NP435 '84 M1009 CUCV Military Blazer 67 C-30 Turbodiesel build thread http://67-72chevytrucks.com/vboard/s...d.php?t=254096 My trucks http://s226.photobucket.com/albums/d...ediafilter=all Member of the 1-Ton Club! Last edited by 67_C-30; 06-22-2008 at 09:38 PM. |
06-22-2008, 09:45 PM | #3 |
did it come with 4.10s? thats what the po said it had
06-22-2008, 09:48 PM | #4 |
its all about the +6 inches
4.10 was standard in small block/automatic 3/4 ton trucks, may have been witht he 4 sped trucks, and avalible in other combos... so yeah, it was avalible in the eaton/corperate HO52 rear end.
06-22-2008, 09:49 PM | #5 |
Most likely, that was the standard gearset, but they could also be had with 4.56, 5.14, and 5.38's. 4.10's are the highest gearset it could have had from the factory, and it is the most common in 3/4 T's.
'67 C-30 Dually Pickup 6.2 Turbo Diesel, NP435 ‘72 C-10 SWB , 350 4bbl, TH350 '69 C-10 SWB , 250 L6, 3 OTT '69 GMC C3500, dump truck, 351 V6, NP435 '84 M1009 CUCV Military Blazer 67 C-30 Turbodiesel build thread http://67-72chevytrucks.com/vboard/s...d.php?t=254096 My trucks http://s226.photobucket.com/albums/d...ediafilter=all Member of the 1-Ton Club! |
06-22-2008, 09:54 PM | #6 |
Cool thanks I was lost there for a min.
06-22-2008, 10:26 PM | #7 |
never heard of the 5.38, not in this generation of truck.
The standard base model C/20 gear was 4.56 |
06-22-2008, 11:38 PM | #8 | |
there was a 5.83, perhaps thats what he means? I think that was only available in the p chassis.
1969 GMC K2500 1996 Honda Accord 2007 Kawasaki KLR 650 |
06-23-2008, 01:12 PM | #9 |
looks like the same rearend I pulled from a 60 chevy 3/4 ton. 4:10 rear end.
1967custom |
06-23-2008, 02:25 PM | #10 |
Is there a list of parts from a 14 Bolt will interchange with these rear ends? I need to know before I just swap a 14 Bolt into mine.
1972 Cheyenne K20 Cool Options Include Manual Throttle - Tilt - Dual Gas Tanks - Sliding Rear Glass ...they just forgot to put a super emblem on at the factory! |
