Old 06-23-2008, 12:43 AM   #1
CUBaseball
CUBaseball's Avatar
Starting Problem
My brother-in-law's 69 C-10 has been having a problem starting and he wanted me to post a question. He just performed a full tune-up but has had a problem cold starting the truck. It will compression start easily and run great, and start easily when warm, but will just crank and crank when cold. He has fairly new edelbrock 1406 on a goodwrench 350 and was wondering if the 1406 might have a fuel bowl issue that is affecting air/fuel mixture on a cold startup. Everything else (electrical, timing, ect.) have been checked but he does know carbs as well as he wants. Any advice will be appreciated.
CUBaseball is offline   Reply With Quote
Old 06-23-2008, 06:56 AM   #2
HomerJ
HomerJ's Avatar
Re: Starting Problem
CUB,
Sounds like your B-I-L has the same issue as a lot of other Edelbrock carb owners have - myself included.
I haven't ever heard of anyone finding the absolute answer to the problem, but many have speculated that the fuel evaporates out of the bowls to the point that the fuel pump has to fill them back up before the engine will fire. This stands to reason (for me, at least), because if I use some type of "startup fluid" or dump a very small amout of fuel into the carb, the engine fires up immediately. As long as I put enough in for the engine to run for a few seconds, everything's good. If I don't put enough in, the engine will still start and run briefly, but will die. I then have to crank until the pump gets enough fuel into the bowls to fill the accelerator pump bore, so it can be used to squirt a blast of raw fuel into the intake.
I have read where some owners of these carbs don't experience the problem, but I believe that most of us do.
Hope this helps....
HomerJ
67 C-10 LWB "Cow-butt-spotted" (neighbor's term) - work in progress. 350/TH400/3.73
67 Chevelle SS Clone 454/TH400/3.73
HomerJ is offline   Reply With Quote
Old 06-23-2008, 08:53 AM   #3
Wrenchbender Ret
Make shure the choke closes tight. Pump the foot feed a couple of times before you start it & continually pump it as it cranks. It,s like Homer says the gas evaporates when setting & it has to fill the bowl. The accel. pump draws fuel from the lower part of the bowl so by pumping it you prime it before the bowl is full. We have gotten so used to these fuel injected vehicles that we forget how to deal with carbs.
Wrenchbender Ret is offline   Reply With Quote
Old 06-23-2008, 09:05 AM   #4
El Jay
Gone to greener pastures
Foot feed?
You're showing our age. How many of these kids knows what a foot feed is?
'69 Chevy 1/2 T LWB Stepper: Daily Beater
'72 GMC 3/4 T Fleet: Another Daily Beater
'72 Plymouth Gran Coupe: ?
"Ah women. They make the highs higher and the lows more frequent." Friedrich Nietzsche
"Never kick a fresh turd on a hot day." Harry S. Truman
GUN CONTROL: Never having to say, "I missed you."
Always fire two warning shots into your attacker's chest area before putting a bullet between his eyes. Paraphrased from Louis Awerbuck
El Jay is offline   Reply With Quote
Old 06-23-2008, 09:31 AM   #5
68gmsee
Active Member
68gmsee's Avatar
Foot feed?? What is that?
I'm not familiar with edelbrocks, but I would check the float level when cold to see if it's drained out completely. Sometimes you can actually see or smell the fuel with the breather removed if it has a bad leak.
Check the needle valve and seat to see if they're bad. Fuel may be leaking back.
68gmsee is offline   Reply With Quote
Old 06-23-2008, 12:24 PM   #6
jonnybravo
jonnybravo's Avatar
i have the same problem with my 68 gmc it did it with the old quadrajet and with a brand new edelbrock i was wondering if i put a check valve in the fuel line it would cure it
jonnybravo is offline   Reply With Quote
Old 06-23-2008, 12:53 PM   #7
CUBaseball
CUBaseball's Avatar
thanks for all the advice, I'll pass it on to him and maybe we can solve the problem.
Old 06-23-2008, 05:19 PM   #8
DREAMS OF A 67
Step Brother
DREAMS OF A 67's Avatar
An electric fuel pump will fix it.
DREAMS OF A 67 is offline   Reply With Quote
Old 06-23-2008, 06:08 PM   #9
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
interesting, I've run edelbrocks exclusivly on all my trucks except the burb for 11 years, and have never had this issue.
Old 06-23-2008, 06:48 PM   #10
72BLUZ
72BLUZ's Avatar
mine has the same setup. i believe they need some sort of check valve in line to keep the fuel from leaking back
Freedom is never more than one generation away from extinction. We didn't pass it to our children in the bloodstream.
It must be fought for, protected, and handed on for them to do the same.... Ronald Reagan
72BLUZ is offline   Reply With Quote
Old 06-23-2008, 07:45 PM   #11
powell72
powell72's Avatar
My wife and I both have Edelbrocks on our trucks, her's has the same problem and mine can sit for a week and light right up with one pump. I was thinking the floats are low on her truck and will be checking them this week. I'll post some feedback when I'm done.
Chris
74 Custom Deluxe SWB 350/350/3.73’s
99 2wd Silverado RCSB 5.3/4L60/3.90’s
http://www.classictrucks.com/feature...short_bed.html
powell72 is offline   Reply With Quote
