06-23-2008, 02:32 AM | #1 |
PIMPING RIDES
Different Heads
I put a motor from a 71 pickup that had manifolds like this [IMG][/IMG] and the manifolds i took out were like this what are the difference is one for a car and the other a truck the first manifolds the spark plugs go on top the second mani the spark plug go on bottom . i'm trying to find heads to fit the bottom pic .what do i need? thanks
1964 CHEVY 1/2 C/10 FLEET 1981 CHEVY 1/2 C/10 FLEET 1995 DODGE 1500 V6 FLEET EAST http://www.flickr.com/photos/bigasspimp/?saved=1 |
06-23-2008, 10:43 AM | #2 |
Dually Pride
Re: Different Heads
I'm going to assume that your engine is a sbc....would straight plug heads be the ones? im not sure, trying to make an educated guess
06-23-2008, 05:36 PM | #3 |
Re: Different Heads
Exhaust manifolds are more about fitting the vehicle. They have to miss steering parts, motor mounts, heater boxes, etc. As long as you are looking at straight plug heads, nearly any of them will fit the manifold.
What you really need to concern yourself with is heads that are right for your engine. Displacement, piston type, etc. |
06-24-2008, 06:23 PM | #4 |
Re: Different Heads
The bottom pic is a manifold for the later models with right hand side dipstick. They won't work on the earlier blocks with driver side dipstick. Fitment on the heads has nothing to do with the heads themselves since the bolt pattern is the same on all of them. ...Joe
I'm not speedin'! I'm qualifyin'! |
