Old 06-23-2008, 03:58 AM   #1
chevychase
chevychase's Avatar
Anyone put a Ford 9" Rear in their C10?
I have a Posi disc brake Ford 9" laying around that I am considering putting in my 67. Anybody done the swap or have any suggestions or pointers?
Joe
chevychase is offline   Reply With Quote
Old 06-23-2008, 08:23 AM   #2
eightbanger
454 MAKES IT ROAR
eightbanger's Avatar
Re: Anyone put a Ford 9" Rear in their C10?
Did you say the "F" word? and in a Chevy. tut,tut,tut.
Nigel.
An American living in a British body.
1971 Chevy Cheyenne 10 454
"In a time of universal deceit, telling the truth becomes a revolutionary act." - George Orwell
"When injustice becomes law, resistance becomes duty" - Thomas Jefferson
No more pain.
03.12.60 -- 12.28.10
http://www.youtube.com/Eightbanger
eightbanger is offline   Reply With Quote
Old 06-23-2008, 08:43 AM   #3
SOON2BLAZE
SOON2BLAZE's Avatar
just did it. Some ECE saddles makes it an easy swap. I used a disc rear from a 75 lincoln. All I need do now is see if I switch the parking brake cables from my 12 bolt and have the drive shaft shortened.
SOON2BLAZE is offline   Reply With Quote
Old 06-23-2008, 08:44 AM   #4
Gray Ghost
Gray Ghost's Avatar
I plan on doing this exact swap someday...is there a build thread on it?
Kelly
'05 GMC Sierra SLE Z71
Bone stock except for new bed rail caps.
Gray Ghost is offline   Reply With Quote
Old 06-23-2008, 08:45 AM   #5
jeremiah king
jeremiah king's Avatar
My buddy did this and they make a kit for our trucks to make it super easy iI will ask him where he got it.
jeremiah king is offline   Reply With Quote
Old 06-23-2008, 08:51 AM   #6
bigsnookmaster
bigsnookmaster's Avatar
I have one in mine.I'm Chevy to the core,but it's hard to beat the 9" for durability,availability of parts,and easy to change out chunks for different gear ratios etc. I've got 3:70 gears,Auburn pro-series posi,Moser 31 spline axles,Strange nodular center,Aerospace rear disc brakes,and a billet steel yoke.So far,I've never had a problem.
bigsnookmaster is offline   Reply With Quote
Old 06-23-2008, 09:35 AM   #7
jkaylor68gmc
jkaylor68gmc's Avatar
I have seen the ECE kit used with a 9-inch, thats what I would recommend
1947 International KB-1
1957 Chevy Bel-Air riding low
1962 swb fleetside
2002 Chevrolet Silverado 7-inch lift on 35 Daily driver
2016 Chevy Tahoe Better halves ride
jkaylor68gmc is offline   Reply With Quote
Old 06-23-2008, 10:24 AM   #8
cdowns
cdowns's Avatar
there aint many cars or lite trucks that you can name where a 9" hasnt been bolted into
Old 06-23-2008, 07:30 PM   #9
chevychase
chevychase's Avatar
Wow, looks like it's more popular than I thought! I found an article from classictrucks about this exact swap. They mentioned ECE as other members have as the source. The article says ECE even has a solution for the panhard bar with their super track kit.
Here's the link:
http://www.classictrucks.com/tech/03...wap/index.html
Here's what I found for the Super Track kit from ECE:
http://earlyclassic.com/catalog.aspx?ProductId=1032
Joe
Old 06-24-2008, 01:59 PM   #10
CochinoFilipino
CochinoFilipino's Avatar
I always thought the GM 12-Bolt was a desirable unit? Is the version in our trucks not so good?
'67 C10 Short Stepside 5.0TPI/700R4
CochinoFilipino is offline   Reply With Quote
Old 06-24-2008, 02:15 PM   #11
smoknbarrels
Registered Mail
smoknbarrels's Avatar
axels are tapered and not enough splines = weak diff.
smoknbarrels is offline   Reply With Quote
Old 06-24-2008, 02:48 PM   #12
Psycho71
Psycho71's Avatar
Yep, it's hard to find a tougher rear end than the 9". Although I have seen a few of them torn up too. But not near as many as 12bolts. The 12 bolts are great rears until you start socking a lot of torque to them in a heavy vehicle.
Should be a fairly simple swap with the saddles and panhard bar kit from ECE.
Jay
You only need two tools in life - WD-40 and Duct Tape. If it doesn't move and should, use the WD-40. If it shouldn't move and does, use the duct tape.
If a hammer doesn't fix it, you have an electrical problem!
Slot Cars, 1:24 Scale, 100MPH@100,000RPM, fastest things on wheels!
Psycho71 is offline   Reply With Quote
Old 06-24-2008, 03:32 PM   #13
CochinoFilipino
I suppose I'm thinking of car applications where Nines are typically 28 spline small bearing versions.
Old 06-24-2008, 05:37 PM   #14
Gray Ghost
Gray Ghost's Avatar
12 bolts are great rear axles when compared to others...except the Ford 9"...they're almost bulletproof. There's a reason why most serious drag racers use them.
Kelly
Old 06-24-2008, 06:17 PM   #15
ratpackv8sonly
ratpackv8sonly's Avatar
I have one in my 1969. Just look for my post as it has pictures of it. I used the purch from a 12 bolt and a panhard bar bracket from a 12 bolt that came out of a 1965 chevy 1/2 ton.
ratpackv8sonly is offline   Reply With Quote
Old 06-24-2008, 06:21 PM   #16
caminokid
Chevy nut
caminokid's Avatar
I used one in the Pinto drag car I had. 383 stroker...5 speed...9 in with 4:56's.
84 Chevy Custom Deluxe 1/2 Ton Named Fade To Black II
"Remember kids there is NO replacement for displacement!"
caminokid is offline   Reply With Quote
Old 06-24-2008, 09:30 PM   #17
Jtrux
I'm a poor spectator
Jtrux's Avatar
I'll be putting a 31 spline 9 inch in my blazer someday, the 12 bolt in it has been a lot of trouble.
2006 Jeep Unlimited IMPACT ORANGE
1993 Chevy 2500 4x4 ExCab LWB 454/NV4500 Tow rig
1977 Ford F100 2x4 LWB 1st truck I owned, still have it!!!
1979 Ford F150 4x4 SWB Built Ford Tough!!!
1971 Chevy Blazer 350 / SM465 / NP205 UNDER CONSTRUCTION Soon to have a LQ4 6.0!!!
Jtrux is offline   Reply With Quote
