Old 06-23-2008, 07:18 PM   #1
crawdad
crawdad's Avatar
Vibration while truck is parked and idling
When I crank up my truck and it is on a fast idle (around 1500 RPM or so), I notice a vibration. I can't tell if its coming from the engine or the transmission. It's hard to explain, but I've noticed that it is not a constant vibration, but seems to be rotational related that vibrates through only a portion of the engine or tranny rotation (if that makes sense at all), i.e., on again...off again, etc. If I give it a few hundred more RPM, the vibration disappears. I don't notice it at all when I'm driving. I use to have another chevy truck that did the same thing and I never did find the cause. I'm wondering if it might be the harmonic balancer or maybe the torque converter. Anybody got any ideas what it might be or things that I need to check? Thanks.
2012 Silverado LT 1500, 5.3, 6 speed auto
'86 SWB C-10 Silverado
crawdad is offline   Reply With Quote
Old 06-23-2008, 08:03 PM   #2
D-Day
Live fast, die young
D-Day's Avatar
Re: Vibration while truck is parked and idling
Is the transmission vibrating against the floorboards? My 700R4 is a tight fit, and will do that sometimes on hard acceleration around a turn.
D-Day is offline   Reply With Quote
Old 06-23-2008, 08:18 PM   #3
C-10volvo
C-10volvo's Avatar
Pull the inspection cover off the tranny and make sure the flywheel bolts are tight. Then start the motor and then look at the flywheel again to make sure it is not bent. If everything checks out it could be something in the motor.
Ken Morgan
For fun: 1964 Volvo 122
For slow: 1984 Chevrolet C-10
For everything else: 1997 BMW M3
C-10volvo is offline   Reply With Quote
Old 06-23-2008, 08:56 PM   #4
COMP
also check your balancer
COMP is offline   Reply With Quote
Old 06-23-2008, 10:05 PM   #5
dammitmitchell
the pollock
dammitmitchell's Avatar
umm tranny mounts...???
Jack of ALL trades, Master of none.. (but one... procrastination)
Army vet 02-08
RIP El Jay! Miss you brother!
http://67-72chevytrucks.com/vboard/s...d.php?t=343538
http://67-72chevytrucks.com/vboard/s...d.php?t=386042
dammitmitchell is offline   Reply With Quote
Old 06-23-2008, 10:19 PM   #6
spoon
Registered Penetrator
spoon's Avatar
Motor mounts.
"Some people wear Superman pajamas. Superman wears Chuck Norris pajamas."
"Chuck Norris is the only person on the planet that can kick you in the back of the face."
"Chuck Norris doesn't 'tea-bag'... he 'potato-sacks.'"
spoon is offline   Reply With Quote
Old 06-24-2008, 12:11 AM   #7
lurch115
lurch115's Avatar
i'd bet on the motor and tranny mounts also....just changed the tranny mount in mine last fall even though it wasn't all that bad and it made a HUGE difference...made it alot quieter in the cab too....
"Horsepower is how fast you hit the wall, torque is how far you carry the wall with you."
'84 chevy half ton short box 2wd, 67,000 actual miles
'03 chevy 1500 HD crew cab 4x4 standard box, 6.0L
lurch115 is offline   Reply With Quote
Old 06-24-2008, 07:55 AM   #8
James McClure
One shot, one kill.
Crawdad, To seperate the problem into engine or trans, unbolt the converter and push it back away from the flywheel. Rotate it 360 degrees to make sure it will clear the flywheel. Start the engine and bring it up to vibration RPM and see if it vibrates. Yes, eng related, No, trans related. Check out what was stated above. IF vibration is very light I would change the mounts. Heavy vibrations are usually accompinied with a noise. Noise= trouble, find it and fix it, jim
1984 K20 350M engine with 465,000 miles. Well, it's finally done!! Almost 2 years of work, but it was really worth the effort. Little stuff left to do is mount winch, wet sand & buff out and build belly pan\running boards. Body work takes lots and LOTS of beer!!!! God, Guts and Guns made America and God, Guts and Guns will preserve it! The worst thing you could do is get into my sights, but that don't matter, you'll never know it, cause you'll never hear the shotJim or Paladin whichever you choose.
James McClure is offline   Reply With Quote
Old 06-24-2008, 09:26 PM   #9
dammitmitchell
the pollock
ohh heres one i had a loud "clanking" during start up idle... it was a loose exhaust mount! he he he....
Army vet 02-08
Old 06-24-2008, 11:04 PM   #10
westie 666
westie 666's Avatar
I had a vibration in a 71 statesman, turned out to be a cracked fan blade it broke off and went through the hood.
77 Cheyenne no longer in bits
westie 666 is offline   Reply With Quote
Old 06-28-2008, 12:06 AM   #11
COMP
so what did you find ????
