Old 06-23-2008, 10:14 PM   #1
dustysdaddy
AC Problems
I recently installed a new ac compressor and condenser on my 1989 Suburban. The system hadn't been used in years. Today when I went to install the new R-134 (after installing the retro kit) The compressor kept kicking on and off every few seconds. I'm stumped and the repair shops just want you to bring it in. Anybody run into this problem? Whats the fix?
dustysdaddy is offline   Reply With Quote
Old 06-25-2008, 07:37 AM   #2
CLASSIC87'
OL BLUU
CLASSIC87''s Avatar
Re: AC Problems
I had a problem similar (it would go off/on when driving)... I replaced the switch that installs in the silver cylinder by the firewall. The part was cheap and fixed the problem...
Anthony
CLASSIC87' is offline   Reply With Quote
Old 06-25-2008, 10:47 AM   #3
dustysdaddy
Re: AC Problems
Thanks Anthony I'll give that a shot.
Old 06-25-2008, 11:12 AM   #4
CLASSIC87'
OL BLUU
CLASSIC87''s Avatar
Re: AC Problems
Sure... the switch tells the compressor to shut on/off depending on how much refrigerant is in the cylinder. Mine was acting up even thou it was full. Also be careful when removing it because coolant will shoot out... be quick and careful!
Anthony
Old 06-26-2008, 12:01 AM   #5
Square84
I don't think these pills work
Square84's Avatar
Re: AC Problems
Anthony
clutch cycling switch or low pressure cutout switch.
SQUARE84
90 SUBURBAN
Square84 is offline   Reply With Quote
Old 06-26-2008, 02:47 PM   #6
dustysdaddy
Re: AC Problems
it goes by either name?
Old 06-26-2008, 05:07 PM   #7
Square84
Square84's Avatar
Re: AC Problems
LOW PRESS CUT OUT WONT LET THE A/C COMP COME ON IF THE SYSTEM IS LOW AS TO NOT TRASH THE COMP. THE CYCLING SWITCH CAUSES THE COMP TO KICK ON AND OFF AS NEEDED TO COOL THE TRUCK.
SQUARE84
90 SUBURBAN
