06-23-2008, 10:36 PM | #1 |
TPI list....
I am about to embark on a swap I thought I would never do....replace my 1405 with TPI from a late model Camaro motor. I like the later model runners
[4 instead of 8] and since my engine is already modified from stock, I will need the MAF sensor version. I am hoping that someone who has done this swap on their 67-72 motor has a comprehensive list of what I will need. I have 2 expert mechanics that will be doing the swap for me, but they are both very busy and I want to get started shoppping for the swap soon. Thanks guys!
Kelly '05 GMC Sierra SLE Z71 Bone stock except for new bed rail caps. |
06-23-2008, 10:59 PM | #2 |
Re: TPI list....
from my experience..... Stay AWAY from painless wiring!!!! Call street and performance.... These guys are good and know their sh*t! The harness is VERY easy to install and well marked... Outside of the wiring harness finding the right fuel pump is key... I used an external pump and the stock tank.. I used a paxton fuel pump I bought from Summit... Good Luck! Its not real hard at all... My motor is a 86 vette motor and I converted it to speed density and eliminated the MAF sensor...
68 C10 Shorty TPI,Bagged, and all the good stuff. Classic trucks feature June 06, On the cover of Jegs Christmas Catalog 08 67 C10 Shorty Shop truck project Bagged and Z'd under destruction and getting nowhere fast. 64 C10 Shop Truck/Daily driver, Bagged, Dropmember, SOLD!!!! Gone but not forgotten.. 54 GMC under the knife getting a S10 chassis swap and bagged. See my build thread... 07 GMC Sierra 5/7 drop, 22's and 24's Air ride on my mind.. http://67-72chevytrucks.com/vboard/s...d.php?t=339340 See pics of my trucks in my profile |
06-24-2008, 12:48 PM | #3 |
The Older Generation
Re: TPI list....
I can't really help with the parts as I'm installing a complete motor/trans setup. A guy I talked to said to use a 1980 Datsun 280zx (Nissan) external Fuel pump, Available at Advance Auto Parts, p/n E8312.. $108. (online price) LockDoc
Leon Locksmith, Specializing In Antique Trucks, Automobiles, & Motorcycles (My Dually Pickup Project Thread) http://67-72chevytrucks.com/vboard/s...d.php?t=829820 - Last edited by LockDoc; 06-24-2008 at 12:49 PM. |
06-24-2008, 02:02 PM | #4 |
Re: TPI list....
I swapped in a 87 TPI into my 72 GMC. I used a painless kit for the wiring, and it wasn't difficult at all. I believe the runners that are together (I think called siamesed) are aftermarket pieces.
I also used an external pump with the stock fuel tank. I don't remember what brand it was though. No problems other than turning corners when below 1/4 tank....so just make sure it's full. I also added an adjustable fuel pressure regulator. Then I had to have a O2 sensor bung welded into the headers. No biggie though. Good luck! |
06-24-2008, 02:05 PM | #5 |
To The Levy
Re: TPI list....
Good choice, my opinion and experience would be to stay with the M.A.F sensor, its more responsive than the M.A.P sensor (speed density sensor system) , you will not be disappointed with the mass air flow system, and your computer will need to match that sensor type system, your harness, o2 sensors, depending if you you are using the cold start injector, not sure, but I think either way can be bypassed. Thats cool of the fuel pump mentioned above , to continue to use factory tank and just install a remote pump, I would wonder if it would not over heat though, due to fact its got to supply higher pressures and not be submerged into fuel to keep cool? anyway, should be a straight up job , use felpro or a good quality gasket . good luck
06-24-2008, 02:34 PM | #6 | |
Re: TPI list....
Just to clear things up.. The painless harness was easy to hook up but painless had swapped wires while it was being built causing a running condition and their tech department just bl*ws!
06-24-2008, 02:39 PM | #7 | |
Re: TPI list....
Gray Ghost, There's alot of TPI info on the web. I have ChevyThunder bookmarked. Here's a pretty good list of parts
'67 C10 Short Stepside 5.0TPI/700R4 Last edited by CochinoFilipino; 06-24-2008 at 02:39 PM. |
06-24-2008, 02:59 PM | #8 |
Re: TPI list....
Another option on the fuel pump if you are going with the stock tank and don't want the noise of an electric pump under the cab is a mechanical pump from:
http://www.racepumps.com/index.html VSS can be had from 'jags that run': http://www.jagsthatrun.com/
70 C/10 Light Red 350/TH350, HEI, Duals w/40 series Flows, 91 seat, LED taillights 99 Pontiac S/C GTP, SLP Ram Air hood, GMPP Konis & springs 95 Neon ACR, MP PCM, AFX UDP, 3.0 CAI Last edited by neonlarry; 06-24-2008 at 03:02 PM. |
06-24-2008, 06:13 PM | #9 |
Re: TPI list....
I definitely want the in tank fuel pump and saddle tank. I now have the in cab tank and it needs to go away. The electric buzz won't bug me, Jana's truck sings a bit now and then so I am used to the sound.
06-24-2008, 06:19 PM | #10 | |
Re: TPI list....
I think we're retaining the cold start injector...Jerrod [my mechanic] said it's a good thing. I am hoping to either get the whole donor car or the whole package from someone who has one. I do want the submerged pump though...gotta get away from the in cab tank. I'll be installing a saddle tank with the pump in it. Thanks for the luck, I will certainly need it!
Kelly '05 GMC Sierra SLE Z71 Bone stock except for new bed rail caps. Last edited by Gray Ghost; 06-24-2008 at 06:24 PM. |
06-24-2008, 09:01 PM | #11 | |
Re: TPI list....
06-24-2008, 09:39 PM | #12 |
Re: TPI list....
I bought a whole 86 Camaro and having the whole car made the swap pretty easy.
I bought a fuel cell with in-tank pump from boardmember fuelcellguy. I bought a V.S.S. from jagsthatrun.com. I bought a Helms manual (very valuable book!!!) and also used info from Chevythunder.com to modify the stock harness to work on my truck. I bought my air cleaner ducting from jagsthatrun.com. I had an O2 sensor installed into my existing exhaust by a local muffler shop. I am sure I am missing a few things but those are the things that were on the top of my mind.
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs. |
06-24-2008, 10:16 PM | #13 | |
Re: TPI list....
