Old 11-09-2002, 07:40 PM   #1
69see20
need help
I am rebuilding the top end of my 307. I was using a pre-oiler to pump oil to the top end. When I took out the tool the rod assembly on the top of the oil pump came out too!! What can I do other than tear down the motor to replace the pump? Any suggestions?
69see20 is offline   Reply With Quote
Old 11-09-2002, 07:52 PM   #2
cableguy0
well uy have to drop the pan. pul out the oil pump and get a replacement rod. because that rod came off now whille it snot running it probab ly just saved ur engine. gm had the brilliant idea of using a teflon collar to hold that rod to the oil pumo. biw theres a replacement rod that has a steel collar. ur oil pump didnt break its just the teflon colar due to 30 yrs of hot oil and heat broke into pieces. get a new oil pump rod and u might as weel get a new oil pump while ur in there thye are cheap.
Owner of North Point Car Care in Dundalk Md. We specialize in custom exhaust on both modern and classic vehicles. We are a full service auto shop from classics to modern vehicles. Feel free to contact me with questions. I will give a 10% discount to any board member.
cableguy0 is offline   Reply With Quote
