Old 06-24-2008, 11:40 AM   #1
Richard D
Richard D's Avatar
Borgeson U Joint alternatives
I am considering "Z"ing my frame. $70+ apiece is pretty steep when you need three of them. Has anyone found a more affordable U Joint? Cosmetics are not important. How strong does it really need to be if I have power steering? All the strain is after the steering box. Also, do I need 3/4-36 splined x DD U Joints on both ends, and DD in the middle?
I found these; they are not DD but may work anyway? I could just use round shafts, with a flat on each end for the set screw. I have a milling machine and lathe.
http://cgi.ebay.com/ebaymotors/Steer...mZ230263925831
Richard D is offline   Reply With Quote
Old 06-24-2008, 02:20 PM   #2
msgross
msgross's Avatar
Re: Borgeson U Joint alternatives
didn't certain vans have U-joints on the steering shaft? might hit the Junkyard...
The Garage:
1968 K-10 SWB - "Project Money Pit"
1996 Z-71 - "huntin rig"
1969 C-10 LWB (SOLD) "Project flip that truck or else"
1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie"
My Garage Build "The 1,000 footer"
msgross is offline   Reply With Quote
Old 06-24-2008, 02:22 PM   #3
Richard D
Richard D's Avatar
I did some more ebay digging, lots of various steering shafts for $20 or less, shaft, u joint, and all. I believe I will be hitting the yard when the time comes.
Old 06-24-2008, 02:51 PM   #4
jkaylor68gmc
jkaylor68gmc's Avatar
Speedway has painted ones that require welding, they are about 35 a peice. They are just expensive. For linkage you can use 3/4-inch cold rolled and cut it to length and use the speedway joints. You just have to weld them, the linkage and u-joints that is, they on't have the set screw like the Borgeson. I don't think I would cheap out here though and go with junk yard units, this is your steering.
1947 International KB-1
1957 Chevy Bel-Air riding low
1962 swb fleetside
2002 Chevrolet Silverado 7-inch lift on 35 Daily driver
2016 Chevy Tahoe Better halves ride
jkaylor68gmc is offline   Reply With Quote
Old 06-24-2008, 03:38 PM   #5
Richard D
Richard D's Avatar
I looked at the Speedway stuff. Still pretty steep. I agree steering is crucial and I don't want anything unsafe, but I would feel just as safe with a 2 or 3 year old junkyard part as I do with my 20 year old stock stuff.
Old 06-24-2008, 08:13 PM   #6
OJOE
Crew Cut
OJOE's Avatar
how much are you going to Z the frame? i helped mike nutt over on the 67-72 ,Z his 69 3in and we used the stock shaft.
85 SWB 1/2 TON CREWCAB/5.3
03 CHEV 3500 DURAMAX CREW CAB
85 CHEV SWB/TPI
06 CHEV TAHOE (WIFES)
30 MODEL A HOT ROD
07 HARLEY DAVIDSON BAGGER
09 STREET GLIDE
AN D A LOT MORE JUNK
OJOE is offline   Reply With Quote
Old 06-24-2008, 10:25 PM   #7
Richard D
Richard D's Avatar
I saw the frame "Z", but no clear pictures of the clearance between the shaft and upper A arm. Was it real close? Maybe it cleared O.K. because it wasn't on airbags, with the A arm all the way up. If so, I may be allright, I don't plan to use bags or lay the frame on the ground. I just want it a few inches lower than it is now, without dragging the crossmember/ A arms.
Old 06-25-2008, 11:12 AM   #8
smashingchuck
It'd be alot cooler if you did
smashingchuck's Avatar
I used Flaming River joints and shaft. Put it together in 20 minutes including building the tower to mount the eye bolt. I wouldn't do anything different.
78 Build Thread
4Runner Build
smashingchuck is offline   Reply With Quote
Old 06-25-2008, 06:39 PM   #9
OJOE
Crew Cut
OJOE's Avatar
yes it is real close but never hits, steering shaft is over pivot point of a frame
85 CHEV SWB/TPI
30 MODEL A HOT ROD
09 STREET GLIDE
