06-24-2008, 07:48 PM | #1 |
Clutch fan replacement
Hello All,
The truck started really making noise today and I thought the motor was about ready to let go, but, when I opened up the hood, I discovered the clutch fan is shot, and when I try to turn the fan by hand, it is really "crunchy" and feels terrible, How hard are these to replace? How do you get inside the large shroud? Is it a really tough job? Thanks all, Rick |
06-24-2008, 08:26 PM | #2 |
Re: Clutch fan replacement
It usually is not too bad of a job. You will want to remove the fan clutch to water pump fasteners first. To keep the pulley from turning, loosen the fasteners first before removing the fan belt.
Once those fasteners are removed then you can remove the assembly and change out the fan on your work bench. If the shroud interferes remove the two upper bolts and pick up the shroud slightly to release it from the lower clips. Jim
1971 Shortbox step side 4x4, 350 sbc, 3:07 rear end 1965 Impala SS 400 sbc, Muncie rock crusher 1966 Impala SS 396 bbc, TH 400 1969 El Camino, 350 sbc, TH 350 1971 Snowplow built on a Blazer frame 1972 GMC Short bed, stepside, TH 400, 427 BBC |
06-24-2008, 08:33 PM | #3 |
Sierra Grande Club
Are you going with a thermostatically controlled unit or just a clutch fan?
s/t
1971 GMC Sierra Grande, 1/2 ton short wide, original 4 bolt 010 020 block & heads. (matching #'s). 383 stroker, SMI q jet 750 cfm, Lunati Voodoo 60102 cam, Scorpion roller rockers, Spin Tech pro street mufflers with X pipe. |
06-25-2008, 09:19 PM | #4 |
its all about the +6 inches
cutting up a box and covering the core of the rad is a pretty good idea too.
And disconnect the battery. Once the alt is loose, it can easily arc out on the engine and melt the harness going across the core support... I'm surprised my hands don't have scars on them from that one. |
06-25-2008, 10:19 PM | #5 |
i just did this yesterday as a matter of fact i just took it off the pully with all the belts on it they helped hold the pully in place and just switch the fan over and re bolt on a total of 8 bolts really simple if i didnt have to go back to the parts store to get the bolts would og been done in 15 minuts
91 gmc k1500 chevy grill power buckets 350 5 speed |
