Old 06-24-2008, 10:00 PM   #1
tylordurben
tylordurben's Avatar
Steering Connection... r/p to column
alright i hope that this thread will be a good reference to source steering issues.
my set-up is a SBC 350, i tried to run "shorty block hugger headers", i am using a MII w/ rack & pinion and i am using the stock column with a "column saver". the issue is that i have to go through at least 2 pipes on the header to make the 2 joint connection. i will look into a mid joint. but my gut says a "ram horn" factory style manifold will be the best solution for clearance.
can everyone please post a pic or two of your set-up with a brief explanation as to what you have?
thanks.
Yaril
ps. i do not have my camera so i will post pics as soon as i get it back, but you can see my pics on my build thread:
http://67-72chevytrucks.com/vboard/s...=289540&page=4
tylordurben is offline   Reply With Quote
Old 06-25-2008, 10:25 AM   #2
orgalmeister
Re: Steering Connection... r/p to column
I don't have any good pics right now, hard drive cr@pped out and took them with it. Anyway what I did was use GM log exhaust manifolds. They have an indentation for steering linkage. I used this setup on my old '47 panel with MMII. And am using the same on my '56.
I did find 1 pic that shows the style of manifolds. I'll try to find more and/or take some pics. Truck goes in for its exhaust Sat.
Steve
'56 truck (the never ending project)
'06 Z/71 loaded (daily driver)
'07 Mercedes-Benz C-Class (wife's driver)
Gone: 72 SB, 67 CST, 57 BBW, 47 Panel streetrod,
orgalmeister is offline   Reply With Quote
Old 06-25-2008, 12:02 PM   #3
solidaxel
solidaxel's Avatar
Look at 78 79 Camaro exhaust.
53 TuTone Extended Cab 350 4-Spd 3:08 (SOLD)
53 Chevy Moldy pearl green ZZ-4 4L60E 9" 3:25
55 GMC 1st Black Mll (ZZ4) ZZ6 TKO 600 5 sp 3:73
62 Solidaxle Corvette Roman Red (327
340hp 4spd 3:36) C4 & C5 suspension tube chassis
LS 3 4L70E
65 Corvette Coupe 327 350hp 4spd 4:11
78 Black Silverado SWB (350/350) 5.3 & 4L60E 3:42
2000 S-Type 3.0 (wife cruiser)
2003 GMC SCSB 5.3 4L60E 3:42
solidaxel is offline   Reply With Quote
