Old 06-24-2008, 10:11 PM   #1
my69camaro1
Young One
Question 14 bolt rear drum removal...
Quick question... Maybe I'm missing something but I can't get the drum off my 14bolt under my trail rig blazer... Brakes will not tighten on this side so I want to put new pads on but can't get it off..
After I pull the rim/tire off it should come off right?
Dorky yes, but i'm lost...
69 R/S Camaro
79 K5
86 M1008
11 P71 Vic
12 Ram 3500
18 Ram 2500
my69camaro1 is offline   Reply With Quote
Old 06-24-2008, 10:28 PM   #2
DirtyLarry
Windy Corner of a Dirty Street
DirtyLarry's Avatar
Re: 14 bolt rear drum removal...
No, if you have a 14 bolt full floater you will need to remove the 8 bolts on the axle flange and slide the axle shaft out then remove the big hub nut and slide the drum and hub assembly off the spindle to gain access to the brake shoes.
DirtyLarry is offline   Reply With Quote
Old 06-24-2008, 10:53 PM   #3
my69camaro1
Young One
Aahhh.. Ok.. Thanks... Yep full floater..
69 R/S Camaro
79 K5
86 M1008
11 P71 Vic
12 Ram 3500
18 Ram 2500
