Old 06-25-2008, 09:19 AM   #1
fastazhell
fastazhell's Avatar
crossmember question...please shed some light
I am about to shorten my LWB to a SWB and I have a question about the rear crossmember where the driveshaft comes through. When I remove the 12 inches from under the cab, the crossmember will move under the cab the same length. I am good with that and was all set until I saw the article on ECE's website where they had to weld their crossmember in after shortening their frame. Just wondering if I am going to have to do that or not. I don't see why I should have to, but maybe I am missing something. FWIW, if I have to reposition it, I am swaping to a dropped version anyway. Was just curious if anyone had some insight so that I could plan ahead.
http://www.earlyclassic.com/tech.asp...Your%20Xmember
this is the link to the article..
Thanks,
Russ
71 LWB c10- needs more work than I have money!
ASE certified Ford Master Tech
fastazhell is offline   Reply With Quote
Old 06-25-2008, 09:31 AM   #2
myoldchevytruck
Retired Air Force Veteran
myoldchevytruck's Avatar
Re: crossmember question...please shed some light
Here is a Build Thread with pictures on how to shorten a LWB. Hope it helps.
http://67-72chevytrucks.com/vboard/s...d.php?t=123624
Harry
69' SWB Step Side 1/2 Ton w/68' Front Clip
Swap from Leafs to Trailing Arms (Complete)
Swap 6 Lug to 5 Lug (w/ Disk Brakes in Front)
3/6 Drop
Help Support The Board
Click Here For Information On How To Subscribe
Krue's FAQ Page
Vendors
myoldchevytruck is offline   Reply With Quote
Old 06-25-2008, 10:29 AM   #3
Dingfodgy
Lemme show you something!!
Dingfodgy's Avatar
If you section your frame under the cab and ahead of the t-arm cross member- you should be fine. Granted you will need to reposition your rear cab mounts 12" back. However if you don't want to lift and or remove your cab for the surgery the frame can be sectioned under the bed, in which case you'll need to relocate the x-member to account for the shorter wheelbase.
'67 CST-10 LWB ("Crusty") SOLD
'67 GMC SWB ("Murdock")
2000 K1500 Suburban ("Betty")
'95 BMW 325i ("Joy")
Dingfodgy is offline   Reply With Quote
Old 06-25-2008, 05:55 PM   #4
fastazhell
fastazhell's Avatar
thats what i was thinking. as long as the cuts were made forward of the x-member, everything should be fine. Appreciate the input!
Old 06-25-2008, 05:57 PM   #5
michael bustamante
michael bustamante's Avatar
if your`re going short bed maybe you could run a 1 piece driveline instead. I`d look ito that If I was doing that conversion
1967custom
michael bustamante is offline   Reply With Quote
