11-09-2002, 10:01 PM | #1 |
Member since 2000
Any one got a set of 6inch lowering springs...if so
can you please measure them for me from the top of the coil to the bottom from the inside. one of the springs i got is a little less then 1/2 inch shorter then then the other. I want to know whats the normal size under pressure in a truck. thanks, with nothing in a bed. if you want picture on how i measured them i will send them to you thanks. oh they are early classic springs, thanks
11-09-2002, 10:25 PM | #2 |
Almost Satisfied
I can go measure mine, but they are not loaded as I am still at just a frame. My only thought is that maybe you have one of the cups different than the other side. I know when I put mine on it really made a difference in how the spring sat based on how I turned the cup.
1971 C10 Stepside. LSx 6.0 with BTR Stage IV, Speed Engineering Headers, 4L80e transmission w/3200 Circle-D Stall. 3.73. Posi. Purchased this truck when I was 17. I started the rebuild (or take apart) in 1993. I have drug it around all over the country in pieces. Finally back on the road in 2021. "I can't complain, but sometimes I still do. Life's been good to me so far." |
11-09-2002, 10:49 PM | #3 | |
Member since 2000
One more thing can you email me a picture of the cut outs and fabrication you did on your frame crossmember for the eaxhaust. thanks |
