Old 06-25-2008, 03:45 PM   #1
kdailey4315
Dash Question
I was looking through the thread where pics of gauges have been posted and I have a few questions.
How do I go from this, with just three holes for gauges
To this example where there are 7 holes.
I know I can just get some after market gauges but will I have to cut up the bezel or can I get one somewhere with pre drilled holes? Will I have to do all the wiring for the gauges that my truck DOES NOT have?
kdailey4315 is offline   Reply With Quote
Old 06-25-2008, 04:33 PM   #2
myoldchevytruck
Retired Air Force Veteran
myoldchevytruck's Avatar
Re: Dash Question
They are wired different. Here's a tip from GMC Pauls website explaining the wiring requirements from the 3 hole (Idiot Light Bezel) to the 7 hole (Gauge Bezel).
Scroll down a few until you see the tip about this conversion. Good Luck.
http://www.gmcpauls.com/Tech%20Tips1.htm
Harry
69' SWB Step Side 1/2 Ton w/68' Front Clip
Swap from Leafs to Trailing Arms (Complete)
Swap 6 Lug to 5 Lug (w/ Disk Brakes in Front)
3/6 Drop
Help Support The Board
Click Here For Information On How To Subscribe
Krue's FAQ Page
Vendors
myoldchevytruck is offline   Reply With Quote
Old 06-25-2008, 05:19 PM   #3
jorgensensc
jorgensensc's Avatar
Re: Dash Question
just an FYI, that green gauge cluster is actually a fabbed up glove box door if I'm not mistaken. It is not the same as the original style 7 hole gauge cluster. If the green one is what you are looking to mimic, then it will take some work. If you want an original style 7 gauge cluster you can buy them from board members and vendors, then just rewire a little, it's not really too hard. Hope this helps some.
Shawn
1972 C20 Suburban- Big Blue Betty
'56 Chevy Bel Air Sedan- Frame up Restoration
-What would you attempt to achieve if you knew you could not fail?-
-I Refuse To Tiptoe Through Life, Only To Arrive Safely At Death's Door-
R.I.P. EAST SIDE LOW LIFE
jorgensensc is offline   Reply With Quote
Old 06-25-2008, 05:22 PM   #4
cparman
sharp as a marble
Re: Dash Question
I bought a Gauge cluster ( 7 hole ) on EBAY, cleaned the lens, replaced the bezel, and DID the GMC PAULS wiring instructions, and about $150.00 later I have Gauges! I am fairly crafty, and it took me 3-4 hours with some help
(read friends stopping by and asking what I was doing ) I is a little intimidating to rearrange the wires in the connector, but write down where tha were, and put them where they need to be. I will go take a pic of my gauges and post it here later.
POSTED PICS ON OTHER DASH THREAD
cparman is offline   Reply With Quote
Old 06-25-2008, 08:43 PM   #5
kdailey4315
Re: Dash Question
Thanks a lot for the link. That is more than helpful. I've seen the FAQ page referenced many times but I can't find it anywhere (probably because it's right in front of my face). Where is it located?
Old 06-25-2008, 10:25 PM   #6
myoldchevytruck
Re: Dash Question
This is located on GMC Paul's website under the tips link
Harry
3/6 Drop
Krue's FAQ Page
Vendors
Old 06-26-2008, 12:47 AM   #7
1969stepside
1969stepside's Avatar
Re: Dash Question
cant you just rewire it without changeing the harness?
Greater love hath no man than to lay down his life for a friend.
Members i Have met
Earl Slick68
1969 Stepside Build thread
http://67-72chevytrucks.com/vboard/s...=1#post4253546
Chevy Trucks the longest lasting most dependable trucks on the road
1969stepside is offline   Reply With Quote
Old 06-26-2008, 08:30 AM   #8
myoldchevytruck
Re: Dash Question
When I rewired, I used an after-market harness and soldered all of the stock pigtails/connectors to the harness. I used all of the stock gauges, switches, etc.
If your using the stock wiring harness and want to rewire into after-market gauges, that should be fine. I would think that with a little common sense, some wire basics and an ohm meter and maybe a dash wiring diagram to tell what color wire is what - you should be fine. Running a ground strap from your dash to the body wouldn't hurt either. Good Luck.
Harry
3/6 Drop
Krue's FAQ Page
Vendors
Old 06-26-2008, 10:37 AM   #9
1-PU70
1-PU70's Avatar
Re: Dash Question
that cluster is mine. I bought it from a board member. Javier I think. I dont think he sells them anymore. Its a billet pice. You could get a similar one from Brothers or other venders. At least you used to. The part I liked was that the gauges mount from the rear for a nice clean look. Here is a pic of the rear. Made my own harness. Price all the gauges (Autometer) Ant the price of the housing and you will probably look for something different. Oh ya and here is a pick of the truck. And yes its for sale. Good luck
1970 CST/10 402,700R4,3:73 posi,AC,PS,PB,TLT,PW,Buckets with heaters
1-PU70 is offline   Reply With Quote
