Door Locks
Hey, the doors and latches on the crew cab work exceptionally well compared to many other trucks of this era. HOWEVER, the locks don't work. Not with the key and not with the actuator/push nob on the door. These are manual lock doors.
I'd really like to get a complete set of new door locks to put in that will all use the same key. . Where should I look for new parts besides LMC? Is LMC the best for new parts such as these? How much a PITA is it to change them out? Is the process covered nicely any manual? Helms? on here as a DIY somewhere? Thanks for your time. ![]()
02 Chevy 2500HD D/A EC SB 4x4 MA SCIII trans, EFI Live, 5" exhaust, 5% tint... 83 GMC K30 Crew Cab Short Bed 06 Duramax & ZF6 (to be installed) and more to come... ![]() Last edited by augie; 06-25-2008 at 09:15 PM. Reason: Against the rules. |
Re: Door Locks
Should I just go ahead and go with electric? I DO like the notion of power door locks.
![]() Here again though, where to look for quality pieces. I know there's bunches of options on Ebay for this but I'm not real sure which ones are good and which ones are cheap and won't last long. C-ya
02 Chevy 2500HD D/A EC SB 4x4 MA SCIII trans, EFI Live, 5" exhaust, 5% tint... 83 GMC K30 Crew Cab Short Bed 06 Duramax & ZF6 (to be installed) and more to come... ![]() Last edited by SmokeShow; 06-25-2008 at 04:58 PM. |
Re: Door Locks
So door locks are good forever and know one has had to replace them before??? Odd.
just being sarcastic, try not to tak eme too seriously. I'm just a joker. Some feedback would be greatly appreciated though. ![]() C-ya
02 Chevy 2500HD D/A EC SB 4x4 MA SCIII trans, EFI Live, 5" exhaust, 5% tint... 83 GMC K30 Crew Cab Short Bed 06 Duramax & ZF6 (to be installed) and more to come... ![]() |
Surviving, one day at a time!
Re: Door Locks
Door locks are somewhat easy to change. Pull the door panel roll window up there is a clip that holds the lock in. remove the clip and the lock will come out. you will need to remove the actuating paul from the lock and re-use it most lock kits don't include them. You can get the replcement locks through LMC, Brothers trucks, or even try a local locksmith.
79 Burb,350,tremic 5 spd, 4 wheel disc, daily driver 74 swb,350,350,driver & future project "There's no such thing as a finished project" |
Re: Door Locks
A new lock set is cheap, I paid $30.00
77 Cheyenne no longer in bits ![]() |
Re: Door Locks
I bought the lock set that has matching ignition key and doorlocks. So now i have no round key. I got mine from classic parts of america. It's a quality lock set, and even comes with GM Keys with the code plugs in the keyring hole. The doorlocks are super easy once you get to em. My haynes manual didn't have instructions for my 78's column, but had detailed instructions for later 80's columns.
Here's a link to the 79-91 key set for 23.95 + shipping http://www.classicparts.com/1979-91-...ctinfo/53-482/ Last edited by 78 Chevyrado; 06-26-2008 at 09:35 PM. |
Re: Door Locks
Now we're talking.
Thanks folks, I'll check these options out. How about electrical ones? Doesn't seem like there is much to hooking them up. C-ya
www.73-87chevytrucks.com
![]() Join Date: Dec 1999
Re: Door Locks
If the locks are not working at all, are all the rods attached? Will the cylinder turn at all?
Chris Lucas 1973 Chevy C-10 1978 GMC Jimmy (2WD) - SOLD 1987 R10 twin turbo LS 1991 R3500 SRW CrewCab 1985 K5 diesel swapped project 1989 K5 2WD conversion w/ Vette susp Project Captkaos Customs 73-87chevytrucks.com |
Re: Door Locks
when i bought my truck it didn't come with a key for the door locks, so i made a quick trip down to the junk yard and pulled a set. the only hard part was finding a truck that still had the door key. cost me $8 and they are still nice an shiny.
Actually taking the locking mechanism out is easy as pie. As far as installing a power lock system...no clue. Oh, and if they don't work at all, i would agree, you should see if everything is connected right before you do anything else.
JG If you can't find it at the junk yard you don't need it. Last edited by Rooster's82; 07-02-2008 at 10:04 AM. |
