Laying frame and towing boats!
Hey guys,
I have been doing a lot thinking about a possible project to take on. Heres what I am thinking- i sometimes see lowered duallies laying frame with bags, that also have the capability to tow a car trailer or 5th wheel. I was thinking I would build a 67-72 that could lay frame and tow my boat! I have read that c-notches arent good with towing- is there some kinda setup I could use to do this? Maybe a custom frame? But I would want it to be a safe as possible. My boats not all that heavy probably like 2500-3000 lbs. |
On the fast track to nowhere..
Re: Laying frame and towing boats!
I think it's doable. To be the safest you could look in to formed rear frame rails. They're actually "bent"(for lack of a better term) over the rear axle instead of your standard cut and welded notches.
-Mike Owen- Norwood, Houston, Cecilia, Jackson, Monroe and counting |
#3 | |
Towing w/properly installed 'step-notches' is ok. Towing w/bolt-in step-notches is not ok. Towing w/a 'generic' cantilever system (KP 6-link) is not ok. I've towed an 18ft car hauler w/the both of my trucks. Both utilize 'bolt-in' style c-notches that have been bolted + welded to the frame for increased strength.
#4 | |
How about bag placement? you mentioned that a generic cantelever setup wouldnt be a good idea. I would guess that putting the bags over the diff would be the best way?
My buddy tows this 48 ft enclosed all the time with his bagged dually that lays frame.. NO issues at all with the bags...
68 C10 Shorty TPI,Bagged, and all the good stuff. Classic trucks feature June 06, On the cover of Jegs Christmas Catalog 08 67 C10 Shorty Shop truck project Bagged and Z'd under destruction and getting nowhere fast. 64 C10 Shop Truck/Daily driver, Bagged, Dropmember, SOLD!!!! Gone but not forgotten.. 54 GMC under the knife getting a S10 chassis swap and bagged. See my build thread... 07 GMC Sierra 5/7 drop, 22's and 24's Air ride on my mind.. http://67-72chevytrucks.com/vboard/s...d.php?t=339340 See pics of my trucks in my profile |
^^^^That is sick! You wouldnt even have to jack the trailer up that much to un hook!
#8 | |
You dont have to jack it up at all... blow air in the bags, set the feet on the trailer down and dump the truck and drive away... He also has cameras mounted near the 5th wheel and the rear drop hitch so you dont have to even get out to back it under the trailer...
68 C10 Shorty TPI,Bagged, and all the good stuff. Classic trucks feature June 06, On the cover of Jegs Christmas Catalog 08 67 C10 Shorty Shop truck project Bagged and Z'd under destruction and getting nowhere fast. 64 C10 Shop Truck/Daily driver, Bagged, Dropmember, SOLD!!!! Gone but not forgotten.. 54 GMC under the knife getting a S10 chassis swap and bagged. See my build thread... 07 GMC Sierra 5/7 drop, 22's and 24's Air ride on my mind.. http://67-72chevytrucks.com/vboard/s...d.php?t=339340 See pics of my trucks in my profile Last edited by c10addict; 06-26-2008 at 01:46 PM. |
The more leverage on the bags the less weight you can put on them. Bag over the axle would give you more carrying capacity, but it will also net a stiffer ride when un-loaded.
When I discussed the cantilever set-up w/Clint @ KP Components, he felt the 'dog-bones' that connect the 4-link/axle to the rear bag links would be the 'weak link' & not like the stress of a heavy load. Bag placement would not be ideal either.
3DrDwn--the 'burb not the band
My old shop dually has an old school 2 link with the bags for everyday driving mounted on the bars. Everything is over built with gussets everywhere and fairly large tubing. Ride is pretty smooth and has great lift for the MT roads. For towing I have a fairly large set of double convoluted bags that are mounted on top of the axle in an even stouter bridge. They're on a separate air circuit and are normally vented so they'll allow the everyday bags to travel normally. When I hook up the trailer I just close the ball valve vent and hit the switch to air them up.
Why 2 sets of rear bags? Well, with standard 224C's in the rear @ the axle the truck lifted higher in the front than the rear at fulll lift. I didn't like the draggin tail look. So I switched to the canti mount and my lift AND ride were great but due to mechanical leverage of the cantilever the towing capacity dropped drastically. With the big Contitec bags over the axle I got all my capacity and then some back. Yeah added expense of 2 more bags, 2 more valves,plus the ball valve but now I get to have my cake and eat it too. I guess after all that the 1 thing I can say for sure if you want to be low and tow ..... over engineer and over build strength into everything. ![]() Shop truck is the orange one and has towed every other vehicle in the pic sometimes two at a time. Purple truck is no lightweight either with several thousand pounds of audio gear and a diamond tilt bed to add to the GVW. Josh PS While I wish ALL of these were mine they in fact belong to one of my best customers/ supporters
Slo and Lo that is the tempo. '72 burb build page here: http://67-72chevytrucks.com/vboard/s...d.php?t=259256 '89 GMC Dually crew build page coming soon. 88 ![]() duallys past/present pics here: http://67-72chevytrucks.com/vboard/s...46#post4001246 89 1 ton Dually rear flip kit install here: http://67-72chevytrucks.com/vboard/s...d.php?t=354327 |
