67-72 Addict!
I bought a black JAZ coolant overflow tank from my local speed shop for $19.95 and 4 feet of hose for $3.25
Jim 1970 C/10 Fleetside w/Ghost Flames Lowered 4.5" front and 4" rear (Raked) 355/350 Turbo w/shift kit 10" Redneck Performance Verter w/2500 stall Hooker Super Comps part#2808-1 Performer RPM Air-Gap 12 Bolt w/3:73 gears- Eaton Posi Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads |
Active Member
![]() Join Date: Jul 2007
Re: Finally installed my overflow tank
I guess I should have looked around a little more. I went to Lowes and got some black pipe and caps to build mine. Cost about $12.
It's not completely finished since I have to paint the red holder from a fire extinquisher black and rerout the hose. I glued the bottom cap but not the top cap. It just fits snug. I can remove the whole thing to clean if I have to. |
68gmsee, that is a Great Idea! Ya don't mind if I copy it?
Ron
Member #111 68 C-10 ![]() 70 ![]() 76 Jeep CJ-5 Help Support the Board: http://67-72chevytrucks.com/vboard/payments.php He who knows nothing is closer to the truth than he whose mind is filled with falsehoods and errors. Thomas Jefferson |
Active Member
Not at all...
I had looked around locally and all I could find was the ugly square plastic bottle that I couldn't get to fit anywhere but the fender well. I had an old fire extinguisher bottle and I rigged up the clamp to work on the tube. A couple of metal screw type clamps could also work. 70c10, sorry for hijack. |
67-72 Addict!
No problem at all 68gmsee. There was a overflow thread awhile back I posted in and said I would post pics when I finished but I got real busy so today I posted them in case somebody was interested.
70C10 Your setup Looks Great also.
Thanks Ron
did you replace the rad cap with one that allows the fluid to be sucked back into the rad when the thing cools down?
67-72 Addict!
On my system I did not. I looked online but couldn't find a cap for my application that did that. My recovery tank has a petcock on the bottom with a release hose but no way of sucking it back to the radiator. It's rare that mine pukes but at least the tank will catch it. Do you know where I can get one?
i'd check at your local napa or better yet a radiator shop
looks good Jim......
1997 GMC Sierra Ext 1965 Mustang |
67-72 Addict!
Ok, thanks. I'll call around.
67-72 parts collector,…
![]() Join Date: Nov 2002
I have the same overflow jug on my blazer. I got the one with return hose instead of the drain valve,... so the fluid is recovered back to the radiator.
#13 |
Active Member
Re: caps. Local auto parts (Auto Zone in my case) have them. I think I paid $5-6 for mine. It's a 13lb cap since I don't have a/c and its a six.
