i have a questiom
how do you take off the steering wheel?
anyone? |
Re: i have a questiom
Unless you are real careful borrow a steering wheel puller (cheapy should work). remove the horn button, nut.
'69 Chevy Long Fleet & '71 GMC Short Step & Project "ODD BALL" "You can wash a pig, soak it in most expensive perfume. In the end it is still just a pig." ODD BALL build thread http://67-72chevytrucks.com/vboard/s...d.php?t=478629" |
Active Member
![]() Join Date: Jul 2007
You can go to Auto Zone and they'll loan you one. You may have to leave a deposit. Don't forget to disconnect the battery cable otherwise you'll be shorting out the horn and making a racket...
If you have harbor freight.... [url] |
steering wheel puller...real cheap and you wont break anything.....remove horn button and loosen nut....put the puller middle section over the hub and find the right size bolts and tighten till it pops off..simple
"Dixie Destroyer" 71 C10 LWB Fleet Future Blown Prostreet Monster |
Or sometimes you can loosen the nut a couple of turns, grab the wheel at 9 & 3 o'clock and pull firmly while someone whacks the nut with a hammer a couple of times. Might save you a trip to the parts house, but requires another person.
But a puller is the best way. Jay
You only need two tools in life - WD-40 and Duct Tape. If it doesn't move and should, use the WD-40. If it shouldn't move and does, use the duct tape. If a hammer doesn't fix it, you have an electrical problem! Slot Cars, 1:24 Scale, 100MPH@100,000RPM, fastest things on wheels! ![]() Last edited by Psycho71; 06-26-2008 at 09:21 AM. |
MOVE OVER
#1 cause of traffic wrecks is the NUT behind the wheel....
![]() j/k what they said, pullers are pretty cheap and easy for these trucks
No matter where you are..... There you are... Buckaroo Banzi |
