Old 06-25-2008, 08:31 PM   #1
prg machine
prg machine's Avatar
setting the door latches
Probably just a lot of trial and error..................but I am wondering f there are short cuts or techniques that have been used to set up the door latch mechanism adjustment to the cab ??????
69 K-20 cloned to a 67 with front clip and some other stuff.
383 .040 over
Crane roller cam lifters and rockers ,1.6 intake ratio, Open chamber heads, 9.5-1 compression ratio, 2.02 intake valves , Edelbrock performer Air Gap manifold Carter AFB performer 750cfm, MSD ignition, SM465 NP205 4.10 gears:
prg machine is offline   Reply With Quote
Old 06-26-2008, 08:55 AM   #2
prg machine
Re: setting the door latches
ttt
383 .040 over
Old 06-26-2008, 09:58 AM   #3
Spoof
Spoof's Avatar
The assembly manual has a specs. for the placement and gaps on the door latch mechanism and striker plate. Sorry I don't have mine with me to scan a pic for you.
71 GMC 1500 LWB
Spoof is offline   Reply With Quote
Old 06-26-2008, 12:08 PM   #4
prg machine
I have all of the original shims etc. from when I took it apart. I guess the actual tricks and techniques are what i was interested in.
383 .040 over
Old 06-26-2008, 12:23 PM   #5
AJs72K5
AJs72K5's Avatar
Mine was just a bunch of trial and error. Watching where the door hit the striker and making small adjustments until they were smooth.
- AJ
Gray Matter Build - 1972 K5 with some stuff
AJs72K5 is offline   Reply With Quote
Old 06-26-2008, 01:19 PM   #6
hotrod 80
mini truck racer
hotrod 80's Avatar
I got lucky on the passenger door and got it first try , but the drivers door im still not happy with . Alot of opening and closing .
1949 5-window
1969 Camaro
1976 Chevy Luv yellow
1978 Chevy Luv Blue
1976 Chevy Luv Black
1979 Firebird Flooded in Harvey
1999 F350 Dually
2005 GMC Sierra 4.8 RCSB
2014 Explorer (wifes)
My build :http://67-72chevytrucks.com/vboard/s...d.php?t=399148
Build #2: http://67-72chevytrucks.com/vboard/s...d.php?t=653583
hotrod 80 is offline   Reply With Quote
Old 06-26-2008, 05:18 PM   #7
PanelDeland
I am a Referee of life.
PanelDeland's Avatar
I have not tried this so take this with a large helping of salt.
After the doors are adjusted(lots of trial and error in that) install the striker postsand slightly snug them.Leave them where they can move but will stay in place.Close the door to set the striker post where it needs to go.Then gently open the door without bumping the striker.The striker should then be adjusted and can be tightened.
As I said this is something I read either here or in one of the car guy mags and I haven't tried it.let us know if this helps.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion.
You can't fix stupid,not even with duct tape.
"My appearance is due to the fact that "GOD" does punish you for having too much fun!"
Barrett-Jackson has perfected alchemy,they make rust into gold!
"You can lead a horse to water but you can't saddle a duck"
"Cleverly disguised as a 'Responsible Adult'
"Sometimes your Knight in shining armor is just a retard in tinfoil"
PanelDeland is offline   Reply With Quote
