Old 06-26-2008, 11:09 AM   #1
abadsvt
abadsvt's Avatar
How much clearance?
Hey guys! I might have a small problem. My rear wheels and tires are a touch to wide. I am going to modify the fender lip on the inside to give me a smiggin more clearance. My question is how much of a gap between the tire and the fender should there be to be safe? I think after i trim the lip a little i would have around 1/2-9/16" per side. Right now i have maybe 1/8" or less. I have a trianglated 4 link and the upper links have quite a bit of angle so i shouldn't get much movement of the rear end. Thanks
Josh
(Project truck)
1970 C10 under complete transformation
My current build thread http://67-72chevytrucks.com/vboard/s...d.php?t=212871
Other project: C5 corvette swap into 70 c10 http://67-72chevytrucks.com/vboard/s...=1#post2413517 On Hold
abadsvt is offline   Reply With Quote
Old 06-26-2008, 11:23 AM   #2
my67chevytruck
Under Construction
my67chevytruck's Avatar
Re: How much clearance?
Josh,
I have a 1/2 clearance between the tire and fender on each side on the rear of my 56 and have not had any issues.
Heath
subscribe to the board here: http://67-72chevytrucks.com/vboard/payments.php
http://67-72chevytrucks.com/vboard/s...d.php?t=157669
FAQ how to's
1956 Chevy Apache
1967 C10 SWB FleetSide (under construction)
1969 K10 SWB FleetSide (Future Build)
1972 C10 SWB Stepside (Future Build)
56 chevy truck :
http://www.cardomain.com/ride/2955823/1
67 truck build:
http://www.67-72chevytrucks.com/vboard/showthread.php?t=281357/1
69 k10:
http://67-72chevytrucks.com/vboard/s...d.php?t=389470
my67chevytruck is offline   Reply With Quote
Old 06-26-2008, 05:57 PM   #3
Hart_Rod
Hart_Rod's Avatar
You should be good............unless you take it out on a roadcourse and get a little crazy......
Hart_Rod is offline   Reply With Quote
