![]() Join Date: Mar 2003
AC work (that time of year)
Well to the point, putting a 400 small block in my 69 GMC 1 ton flat bed with a serpentine kit which uses the smaller AC compressor. I want to clean up the rest of the engine compartment and get rid of the POA system. I seem to recall about 3-4,5? years ago an article in here---YES I SEARCHED-- about pulling the box apart and installing an OLDS? evaporator and using a receiver/dryer along with an expansion valve and 134a. Anybody recall this? I even printed it out but have lost it.
On the road
![]() ![]() Join Date: Jan 2004
Re: AC work (that time of year)
There was a good one in the FAQ as I recall.
Mike Castro- 72 SWB. Ochre and White. 496/400 turbo, GV OD ,Dakota Digital dash , tilt, Vintage Air, PS, hydro boost, factory buckets, console, QA-1 Coil over suspension, 20/20"Billet Specialties Magnetos 72 SWB. Med blue. 454/400 turbo, tach, tilt, Stock AC, PS,PDB, factory buckets, console, ECE 4/6 drop w/ 2" blocks and C-notch, 20/20"Coys- Crashed and destroyed by drunk driver Sept 2019. New 72 build in the works. My new build thread "Castro" https://67-72chevytrucks.com/vboard/...d.php?t=820934 My old build thread, the blue truck http://67-72chevytrucks.com/vboard/s...d.php?t=271489 www.louisianaclassictruckclub.com |
Got a link? I couldn't find it--- I looked for just about an hour
Keep the POA:
http://www.autoacforum.com/messagevi...AR_MSGDBTABLE=
'70 cab, '71 chassis, 383, TH350, NP205. '71 Malibu convertible '72 Malibu hard top Center City, MN |
Here are a couple of old links:
http://67-72chevytrucks.com/vboard/s...d.php?t=113552 http://67-72chevytrucks.com/vboard/s...d.php?t=112463 Also you do know you can get R12 compressors for a serp setup. Mine came off a 96 9C1 Caprice.
![]() ![]() 99 Pontiac S/C GTP, SLP Ram Air hood, GMPP Konis & springs 95 Neon ACR, MP PCM, AFX UDP, 3.0 CAI |
On the road
The post by bobbyk is the one I remember and neon larry has posted a link to it above. That was a good thread.
Thankfully I didn't have that problem when I installed my new A/C in my '63 a couple months ago. It was a nice, clean install.
