Old 06-26-2008, 08:27 PM   #1
MattyBs71
MattyBs71's Avatar
Temp Gauge problem again
Hi all,
Background info:
I just picked up some gauges, not sure if they all work. Anyway I converted from idiot lights to gauges by moving the wires in the instrument cluster as GMCPaul instructed on his web page of tips. I picked up a new sending unit for gauges. I also picked up a new Printed Circut board to replace the one on the gauges I got as it had a burned spot.
Here is the problem, the temp gauge has been steadily moving up towards hot and has never gone back down to to cold. Yesterday was the first day I drove the truck since I did the upgrade. I get in the truck this AM and the temp is still at the same position it was last night. Also when I installed the gauge it wasn't reading cold it was up a bit on the temp and has just moved up more and never back to cold.
What's wrong?
Another quick question. Does the Fuel gauge go to empty when the truck is off and key out? Because mine is reading full all the time, even when the truck is off.
MattyBs71 is offline   Reply With Quote
Old 06-26-2008, 08:40 PM   #2
70LonghornCST
Moderator
70LonghornCST's Avatar
Re: Temp Gauge problem again
There are small, flat resistors that are needed on the back of those gauges; are they present? If not, I have a couple I could send you no charge.
2018 Chevy Crew Cab
2006 Impala SS
1965 Plymouth Sport Fury
1970 Chevy Longhorn
  • Bucket Seats
  • Shoulder Belts
  • Front Tow Hooks
  • Factory Air
  • Factory Speedwarning, Tach & Vaccum
  • Factory Tilt
  • CST Package
  • AM/FM Radio
  • Bumper Guards
Richard
70 Longhorn CST Build
Adding an AM/FM Decal
70LonghornCST is offline   Reply With Quote
Old 06-27-2008, 09:57 PM   #3
MattyBs71
MattyBs71's Avatar
Yes the resistors are there.
Old 06-28-2008, 09:01 AM   #4
acl
acl's Avatar
don't want to change topic but what do this resistors look like. can't get temp gauge to work as well
acl is offline   Reply With Quote
Old 06-28-2008, 10:18 AM   #5
72BLUZ
72BLUZ's Avatar
a little flat piece of ceramic with copper center and 2 holes to connect to the gauge
Freedom is never more than one generation away from extinction. We didn't pass it to our children in the bloodstream.
It must be fought for, protected, and handed on for them to do the same.... Ronald Reagan
72BLUZ is offline   Reply With Quote
Old 06-30-2008, 11:49 PM   #6
FXJETS
Check the sending wire. Ground the wire and check the needle swing. then open the connection and the needle shoud swing in the oppisite direction. if not the gauge is bad, or the resister is bad.
FXJETS is offline   Reply With Quote
Old 06-30-2008, 11:59 PM   #7
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
to add to that, you need the ignition switch to be on.
Plus, this will test the whole system, except the sending unit. The wire, fuse, PCB, guage, resistor... etc.
Old 07-01-2008, 10:50 AM   #8
MattyBs71
MattyBs71's Avatar
I figured it out, a bad fuse that runs to the cluster on the fuse panel under the dash, this fuse fixed my fuel gauge and temp gauge problems!
