06-27-2008, 12:27 AM | #1 |
vaccum leak
Ok I'm trying to find a vaccum leak, already sparyed the intake and carb gaskest, and replaced them when i lost all my coolant. There is only the vaccum advance, pcv, and the vaccum modulator hooked up and their not leaking. its a loud hiss and it gets louder with no air cleaner. I'm out of ideas.
THANKS!
1970 GMC 4/6 drop built 350 with double humps, autometer phantom gauges. WORK IN PROGRESS. |
06-27-2008, 08:52 AM | #2 |
The Older Generation
Re: vaccum leak
What do you have for a carb and intake? I had a similar problem and it was because I had a square bore manifold and a spread bore carb. Once I put an adapter on it the vacuum leak went bye-bye.... Just a thought. If your leak is that loud it may be a port on the carb that isn't capped. LockDoc
06-27-2008, 09:10 AM | #3 |
Active Member
Re: vaccum leak
Looks like you've checked the obvious. I don't know if you have a mechanic's stethoscope but I've always found out that I need help to isolate the hard to find noises.
My favorite noise finder is a 3 foot long piece of garden hose. I can snake it into hard to get to places and works great for me. The stethoscope is good to free up one of the hands in case you need to flex tubes or rev the carb up, etc... |
06-27-2008, 04:04 PM | #4 | |
its all about the +6 inches
Re: vaccum leak
make sure it isn't from the carb its self... down in the body. Some carbs make a lot of noise.
your comment of; Quote:
06-28-2008, 05:39 PM | #5 |
Re: vaccum leak
well its got a edelbrock carb and manifold. No ports are open. And I'm having a hard time trying to set the mixture right its always to rich, and its had two different edelrock carbs on it.
THANKS!
06-28-2008, 06:38 PM | #6 |
Old Skool Club
Re: vaccum leak
My truck had an Edelbrock 1401 on a stock intake, with an adapter, when I bought it. It, too, ran rich....burn your eyes!! When I replaced the intake with an Edelbrock and an Edelbrock 1901 (Q-Jet), the rich combustion odors went away. In fact, the combustion temps went up and I had to put a heat shield on the starter, due to heat soak.
If your carb is also a 1401, they are jetted rich, from the factory. Go to www.edelbrock.com and you can access their tech pages, which will tell you waaaaaaay more than you probably want to know about all aspects of setting these carbs.
Member Nr. 2770 '96 GMC Sportside; 4.3/SLT - Daily driven....constantly needs washed. '69 C-10 SWB; 350/TH400 - in limbo The older I get, the better I was. |
06-28-2008, 11:02 PM | #7 |
Msgt USAF Ret
Re: vaccum leak
Here'sa great site for eelbrock tuning.
http://www.edelbrock.com/automotive_...ers_manual.pdf
VetteVet metallic green 67 stepside 74 corvette convertible 1965 Harley sportster 1995 Harley wide glide Growing old is hell, but it beats the alternative. |
06-28-2008, 11:40 PM | #8 | |
Re: vaccum leak
LockDoc
06-29-2008, 05:15 PM | #9 |
Re: vaccum leak
well they are both for sure square bores. it does have a carb spacer though.
