Old 06-27-2008, 07:17 AM   #1
energiesource
Rear leaf spring to rear coil conversion?
I was wondering if this was possible and how hard it is to do? there seems to be more aftermarket kits for the coil springs
energiesource is offline   Reply With Quote
Old 06-27-2008, 07:28 AM   #2
myoldchevytruck
Retired Air Force Veteran
myoldchevytruck's Avatar
Re: Rear leaf spring to rear coil conversion?
Just did that conversion with 6 inch drop coils.
Harry
69' SWB Step Side 1/2 Ton w/68' Front Clip
Swap from Leafs to Trailing Arms (Complete)
Swap 6 Lug to 5 Lug (w/ Disk Brakes in Front)
3/6 Drop
Help Support The Board
Click Here For Information On How To Subscribe
Krue's FAQ Page
Vendors
myoldchevytruck is offline   Reply With Quote
Old 06-27-2008, 07:37 AM   #3
energiesource
know of a how-to or anything to help me along? its the least of my worries on this project from hell i have but still would be good to know
Old 06-27-2008, 08:01 AM   #4
myoldchevytruck
It was not a bad conversion. My question to you, is how is your parts availability? I was fortunate, I bought a coil spring setup from a swap meet from a board member. It included the trailing arms, original coils, lower shock brackets and coil cups with hardware. As I said in my 1st post, I went to 6 inch drop coils.
Things you'll need are:
Trailing Arms
Coil Springs
Coil Cups and hardware
U-Bolts
Cross Member brackets (bought from a board member, (I think $20.00 plus shipping)
Axle Saddle brackets (bought from ECE, $29.00 plus shipping)
Lower Shock Brackets (I have a set if you want for free, you pay shipping)
Track Bar to Frame Bracket ($20.00 plus shipping from a board member)
Rear Track Bar (if you go stock, I may have one for you free, you pay shipping)
The leaf and coil rear axles are different. If you can get a coil rear end that would be great. If not, you'll have to cut, grind and clean the axle so you can install the Axle Saddle brackets mentioned above. These brackets hold the entire setup to the rear end.
As for the old leaf setup, my biggest dilema was getting the factory rivet off to remove the leafs and associated brackets.
I know this is long winded, but if you need help just PM me. I'll try to get some pictures later today.
Harry
3/6 Drop
Krue's FAQ Page
Vendors
