Help! Bear Claw Latches 55/2 - 59
Somewhere on here I saw a great post about installing bear claw latches. Could someone point me in the right direction? Thanks much.
Re: Help! Bear Claw Latches 55/2 - 59
Don't know how great it is but here is the material I put together for installing them on an Advance Design model. Some of this may help you out. You might check the Jalopyjournal site also as I recall coming across another installation there. Good luck.
I will be doing this mod to the 58 in the future so take some notes and pics of your installation as it may be useful later. http://www.picturetrail.com/sfx/gallery/view/19808817 |
![]() Join Date: Mar 2008
I thought there was some more info on the TF truck also.
Here is a mag article on it. Not for our trucks but may help. bearclaw pdf
2001 GMC SIERRA 1956 Chevy Panel Build Page with a Scott's Hotrods IFS 1953 Chevy trucks Project Dime Time 1968 Camaro 1968 Volksrod "NOBACK" Jared |
Thanks both of you, the information is great. However I guess I should have been a little more specific............there was a post of a guy on here that mounted the latch on the cab and the post on the door. It made for a very clean install and this is the direction I want to go. I know it is just a matter of reversing the pieces, but, was hoping to see his/her article in case there are some hidden challenges that is presented with that configuration. Thanks again.
Houston54, I will shoot you a PM in reference to your question(s). |
Yellow truck club
Try this about 2 3rds way down
http://67-72chevytrucks.com/vboard/s....php?p=2771184 rod and custom article http://www.rodandcustommagazine.com/...latch_install/
................................................................ Brian ...... ![]() My hub garage address http://www.hubgarage.com/mygarage/59apache I gue$$ everything has it'$ price ALL GONE NOW ![]() ![]() ![]() ![]() PRAISE THE LOWERED 350 700r lokar shifter power MII front end, shockwaves tilt, 4 wheel discs 4-link and bags 10 bolt limited |
