Old 06-28-2008, 02:12 AM   #1
Pont406
Does this support bearing look bad?
I am getting real bad vibration when cruising at 3800-4000 rpm and it's not from the tires. I replaced center support bearing 2000miles ago. I think it's coming from the driveshaft. I suspect a bad support bearing again.
Pont406 is offline   Reply With Quote
Old 06-28-2008, 04:14 AM   #2
COBALT
COBALT's Avatar
Re: Does this support bearing look bad?
Coming from someone who just had their driveshaft break just forward of the bearing I'd say yeah it looks like the boot that holds the bearing centered has let loose. The removable yoke doesn't look like it's centered. That thing is probably hopping around in there.
'69 3/4 ton C20 2wd-350ci/TH400
'69 3/4 ton Custom 20 2wd-350ci/4sp Manual
'99 2wd 5.7 Chevy Tahoe
Seattle, WA.
COBALT is offline   Reply With Quote
Old 06-28-2008, 06:05 AM   #3
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
crawl under there and grab the shaft, push, pull, twist, jerk on it, just give it hell. If it clunks, time to see your friendly drive shaft shop.
Old 06-28-2008, 07:07 AM   #4
Gray Ghost
Gray Ghost's Avatar
Did you replace ALL the u-joints when you did the carrier bearing? If not I'd bet that's the problem.
Kelly
'05 GMC Sierra SLE Z71
Bone stock except for new bed rail caps.
Gray Ghost is offline   Reply With Quote
Old 06-28-2008, 07:22 AM   #5
truckdude239
truckdude239's Avatar
looks bad to me
David fuller
Ase Certified Mechanic
Click here to help support our board!!
1971 Chevy c-10 under going a 4.8l LSx swap
Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=421305
2007 Honda Accord my daily 145kmiles
2002 Honda Accord 4 door With 330k(sisters car)
2005 toyota Avalon 228k( brothers car)
2002 Sububran 5.3 245k
2000 Tahoe 5.3l 378
General manager for Marco's Carwash & lube
truckdude239 is offline   Reply With Quote
Old 06-28-2008, 07:32 AM   #6
Boog
laying low
Boog's Avatar
[real bad vibration when cruising at 3800-4000 rpm ]
That's a lot of cruising rpms there Pont. What setup are you running?
Boog
69 Chevy stepside, 358/T350, 4.11 posi, 4.5/4 drop, rallys, poboy driver
primer is finer
91 Chevy sportside, Tahoe, Yukon & GMC Crewcab All GM..'nuff said.
Old 06-28-2008, 10:08 AM   #7
7DEETWO
7DEETWO's Avatar
What the heck is going on here I no sooner posted on the prior thread regarding Center Support Bearing and ran into this thread. Is this always a problem or am I just taking notice to this issue because it happened to me?
7DEETWO is offline   Reply With Quote
Old 06-28-2008, 11:07 AM   #8
VetteVet
Msgt USAF Ret
VetteVet's Avatar
The last post in a thread bumps it to the top of that forum. If you check the times of the posts they are not too far apart, so you would see them fairly close together in the forum. If your post is less than 5 minutes apart from another poster in the same thread you may not see his post until after you submit yours. You both could be saying pretty much the same thing but one post will show before the other. With 30,000 plus members a lot of posts are going into these threads. Don't worry about it. If you need a more detailed explanation PM a mod or administrator.
VetteVet
metallic green 67 stepside
74 corvette convertible
1965 Harley sportster
1995 Harley wide glide
Growing old is hell, but it beats the alternative.
VetteVet is offline   Reply With Quote
Old 06-28-2008, 11:13 AM   #9
7DEETWO
7DEETWO's Avatar
I understand how the threads are posted. I was actually referring to the Center Bearing it self…is this always been a problem with our trucks?
Old 06-28-2008, 01:46 PM   #10
john
member #16
john's Avatar
Are your u joints in time with each other?
john is offline   Reply With Quote
Old 06-28-2008, 03:46 PM   #11
PanelDeland
I am a Referee of life.
PanelDeland's Avatar
Center support bearings are a common problem.Mostly because they are 40 years old and not everyone realizes the driveline must be timed/indexed/phased properly.Many times PO's did U-Joints themselves and did not keep them phased.I am giving generalizations here since I don't know what your situation is.If the rear half was installed 180* out from it's original balance point then the driveshaft will be unbalanced.Most have found that a drivelline set up by a pro shop will last years but many have done their own and gotten only a few months from them.Hope this helps with info on driveline problems,even though it doesn't solve them.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion.
You can't fix stupid,not even with duct tape.
"My appearance is due to the fact that "GOD" does punish you for having too much fun!"
Barrett-Jackson has perfected alchemy,they make rust into gold!
"You can lead a horse to water but you can't saddle a duck"
"Cleverly disguised as a 'Responsible Adult'
"Sometimes your Knight in shining armor is just a retard in tinfoil"
PanelDeland is offline   Reply With Quote
Old 06-28-2008, 04:05 PM   #12
Hart_Rod
Hart_Rod's Avatar
I think I'm going to switch to this billet piece:
http://www.classicperform.com/Store/...ruck/CPSSD.htm
Hart_Rod is offline   Reply With Quote
Old 06-29-2008, 02:34 AM   #13
Pont406
I marked it all before replacing u-joints and a center support bearing. I also used a press. Before I had a 3.08 gears and vibration was barelly there. After installing 4.10 gears I can feel a lot more. Anyway that bearing has a life time warranty. Hopefully it's just a faulty bearing.
Old 06-29-2008, 10:48 PM   #14
Phaedrus
Phaedrus's Avatar
If your vibration got worse when going from 3.08 to 4.10 gears you have a balance issue. Your driveshaft is now spinning much faster at any given road speed making the imbalance more noticeable. The same imbalance will fatigue the rubber style carrier bearing very quickly, making the vibration felt even worse yet. Replace the carrier, have the driveline dynamically balanced and you'll be set.
Phaedrus is offline   Reply With Quote
