06-28-2008, 06:21 PM | #1 |
Tie-rod ends etc. ??
who is making the best parts and why for a 77 2wd ????
06-28-2008, 07:01 PM | #2 |
Manual Transmission Club
Re: Tie-rod ends etc. ??
I’ve been using Moog for years. I’ve done the front end with all Moog parts on two Toyotas and I’m in the process of replacing all chassis parts with Moog on my 2X4 79 Sierra right now. All their parts are high quality and last, I’ve never had to re-replace any of their parts.
79 GMC Sierra Grande, SWB, Heavy Half If I wanted easy I would just buy a NEW truck! |
06-28-2008, 07:04 PM | #3 |
Surviving, one day at a time!
MOOG all the way!
79 Burb,350,tremic 5 spd, 4 wheel disc, daily driver 74 swb,350,350,driver & future project "There's no such thing as a finished project" |
06-28-2008, 07:10 PM | #4 |
what about Spicer ??
06-28-2008, 07:31 PM | #5 |
One day...
too moog all the way! Ya spicer is good too
06-28-2008, 07:41 PM | #6 |
my MOOG parts are wearing out
06-29-2008, 04:09 PM | #7 |
no other companys ????
06-29-2008, 05:52 PM | #8 |
Thats the only one I use for steering linkage and balljoints. As long as you keep them properly lubed the last a long time.
06-29-2008, 10:03 PM | #9 |
06-29-2008, 10:33 PM | #10 |
06-29-2008, 10:47 PM | #11 |
06-29-2008, 10:53 PM | #12 |
One day...
Was that a hard 30-32K?
I would expect mine to wear out faster than usual way i treat them sometimes But ya you would figure they would last longer.. |
06-29-2008, 11:00 PM | #13 |
06-30-2008, 12:51 AM | #14 |
Rebuilt my entire front-end with Moog parts back in 2002. Rock solid. All you need is a grease gun.
'69 3/4 ton C20 2wd-350ci/TH400 '69 3/4 ton Custom 20 2wd-350ci/4sp Manual '99 2wd 5.7 Chevy Tahoe Seattle, WA. |
06-30-2008, 11:13 AM | #15 |
06-30-2008, 05:17 PM | #16 |
found out Napa's low line is off-shore and there Chassie Line is SealedPower
06-30-2008, 09:43 PM | #17 |
30-35K??? Seems like you should get more then that out of it. Did you hit something maybe? Like a big pot hole or a curb? Or it could be an underlying problem like bad alignment, oversized tires (too wide especially), aggressive turning, bad gear box, any number of things. With out looking at your truck it’s hard to say. I expect to get at least 100-150K out of my front end job, then again I’m replacing everything:
Rag joint Gearbox (cardone) Pitman arm (Moog) Tie rods (Moog) Adding a steering dampener (Moog) Idler arm (Moog) Keeping spindles and the bar that attaches to the tie rods they’re in good shape Ball joints upper/lower (Moog) Control arms (making my own) Control arm shafts (Moog) Adding sway bars front and back (Addco) Control arm bushings (Energy Suspension) Body mounts (Energy Suspension) Shocks (Rancho)
06-30-2008, 10:06 PM | #18 |
got back from the Zone,,,,,the $8 end was China the $13 was Mex. ,,the side by side was amazing ,,,,the $8 would work for a car,,, but at 4280lbs min.
I wouldn't try it ,,,wish i has Napa closer to see a good one Oh well tape measure and tools tomorrow |
06-30-2008, 11:01 PM | #19 |
Your going to find that all large companys have parts manufactured in foreign countrys. Labor is cheaper which cuts costs. That dosn't neccesarily make the product poorer in quality. Alot of the GM crate engines are made in Mexico some of the trannys are made there too. Every company does whatever they can to cut costs and increase profit thats just how big buisness works. It's all about the bottom line.
