Ignition Switch
Having problems removing ignition switch and bezel. Removed wiring harness. Switch and bezel rotate in dash not sure what to do next. I'm sure its simple, just seem to be missing it. Would also like to be able to put harness back on once out as I sill start and move blazer occasionally. What am I missing?
#2 | |
Member since 2000
Re: Ignition Switch
Edit: deleted everything cause I was wrong
Here is a thread that will give you the anwser. CLICK ME Quote:
Re: Ignition Switch
Thanks, Knew I had to use a paper clip but wasn't sure about key position, will try in the am. Thanks again
