Old 06-29-2008, 01:04 AM   #1
hessian18
Gen III Power
hessian18's Avatar
Mystery Wires Help Please
I cannot for the life of me figure what exactly these wire are for....and also this small sensor....
Its on the driver side toward the rear of the head....
Its an Inline 250.....
From what I have found the greenwire is the temp sensor wire ?? The other wire is orange with a black line.....
I have replaced the temperature switch....is this different from the temp sensor ??
My gauge just goes slowly until its pinned out....If I ground it out...it goes instantly.....Im confused LOL
---Bob---
'81 Long Box. 2005 5.3l Vortec and 2005 4L80e coming soon...
hessian18 is offline   Reply With Quote
Old 06-29-2008, 01:19 AM   #2
jrsmith_2010
I like turtles...
jrsmith_2010's Avatar
Re: Mystery Wires Help Please
hmmmmm, idk, could it be a sensor for the AC?
jrsmith_2010 is offline   Reply With Quote
Old 06-29-2008, 01:22 AM   #3
hessian18
Gen III Power
hessian18's Avatar
Im not sure....
I did figure out where the idle up solenoid wire went for the A/C.....
Im just wondering why my temp gauge is still acting up...
Thats not a oil pressure switch is it ??
---Bob---
Old 06-29-2008, 01:24 AM   #4
70LonghornCST
Moderator
70LonghornCST's Avatar
What I am seeing in your pics are two sensors. The one on the block is an oil pressure
sensor, the one on the water neck is the heat/water temp sensor. I am not sure which wires go to which. You may need do trial and error. You wont mess anything up if they're crossed, I believe.
2018 Chevy Crew Cab
2006 Impala SS
1965 Plymouth Sport Fury
1970 Chevy Longhorn
  • Bucket Seats
  • Shoulder Belts
  • Front Tow Hooks
  • Factory Air
  • Factory Speedwarning, Tach & Vaccum
  • Factory Tilt
  • CST Package
  • AM/FM Radio
  • Bumper Guards
Richard
70 Longhorn CST Build
Adding an AM/FM Decal
70LonghornCST is offline   Reply With Quote
Old 06-29-2008, 01:26 AM   #5
jrsmith_2010
I like turtles...
i agree, trial and error is the way to go to figure it out.
Old 06-29-2008, 01:40 AM   #6
Big68
The sensor is definitely a water temp sensor, and that is what the green wire goes to.
As for the other wire, I'm not sure. Have you tried to trace it and see where it ends up?
1968 GMC, 2wd to 4wd conversion, automatic to manual, 4 in custom lift, 36'' military tires, recent 454 upgrade
1979 Pontiac Firebird, mildly built sb 350, t56 trans
Big68 is offline   Reply With Quote
Old 06-29-2008, 01:44 AM   #7
hessian18
Gen III Power
hessian18's Avatar
So that small sensor is also a temp sensor ??
I couldnt find anything like it at the parts store....
The orange wire with the black stripe goes back into the loom with the green wire...I havent gone any further into the loom...
---Bob---
Old 06-29-2008, 02:01 AM   #8
Big68
I'm almost certain that the small sensor is also a temp sensor. I've gotten into many vehicles that had two even [U]three[U] temp sensors. It seems that a PO will just keep adding them wherever they can. A quick way to see if it's a water temp sensor or an oil pressure sensor is to take it out and see what kind of fluid comes out. If it's an oil pressure sensor there probably won't be anything come out unless you leave it running. (not recommended!), but you'll be able to see oil on the end of it.
I've got a '65 250 I-6 in my '68 GMC, and the boss for the oil pressure is on the passenger side right under the side cover at the rear of the motor. That doesn't mean that GM didn't change locations, but I don't think they'd put it in the head.
Old 06-29-2008, 02:57 AM   #9
70LonghornCST
Moderator
Yes, that is right. In retrospect of Big68's post, I agree. The oil sensor is located on the opposite side (passengers). The small sensor located on the driver side of the block below the valve cover IS a water/temp sensor also. The larger brass colored one on the water neck is an aftermarket type. You certainly have 2 installed. When I had my last truck with an inline 6, I installed an aftermarket gauge on the waterneck. I wanted to get rid of the warning light since it is Hot in the central California valley Where I live.
2018 Chevy Crew Cab
2006 Impala SS
1970 Chevy Longhorn
  • Bucket Seats
  • Shoulder Belts
  • Front Tow Hooks
  • Factory Air
  • Factory Tilt
  • CST Package
  • AM/FM Radio
  • Bumper Guards
Richard
Old 06-29-2008, 05:41 PM   #10
hessian18
Gen III Power
hessian18's Avatar
Well now im real confused....
Both of these sensors are in factory locations with factory wiring...If you pull the wiring back its all in the stock loom with the original GM tape and everything LOL
I cant find that little sensor anywhere......only sensors I have found that are Tu65 Tu66 which are for the water neck......
hmmmm
---Bob---
Old 06-29-2008, 06:48 PM   #11
GMBowtie79
Surviving, one day at a time!
GMBowtie79's Avatar
Pull it out, it's probably a oil sensor. Try hooking the wire with the orange connector on it to that sensor it looks like it is very close to where the wire would end length wise and it has the correct type of end on it. the sensor in the water neck looks like one for a light not a gauge. I just went through that conversation with the guy at the parts store last weekend P/o of my truck had the wrong one in mine and the gauge wouldn't work properly. Changed it and it works now. Dissconnect the waterneck one and hook up the other one and see what happens.
79 Burb,350,tremic 5 spd, 4 wheel disc, daily driver
74 swb,350,350,driver & future project
"There's no such thing as a finished project"
GMBowtie79 is offline   Reply With Quote
Old 06-29-2008, 06:57 PM   #12
hessian18
Gen III Power
hessian18's Avatar
Im going to pull it out tonight when the motor cools off....
Im trying to find a wiring diagram...so far no luck...
---Bob---
Old 06-30-2008, 09:03 PM   #13
hessian18
Gen III Power
hessian18's Avatar
Well I pulled the sensor today....It IS a coolant sensor....
I tried testing it with a DVOM but wasnt showing anything....
The part number is 14025299 1028...that is stamped into it.....
I cant find that part number on any websites....
I also traced the wires more back into the loom...both wire going to these sensors are green......
The orange and black wire is still a mystery LMAO !!
---Bob---
Old 06-30-2008, 10:10 PM   #14
GMBowtie79
GMBowtie79's Avatar
I was just reading a article that was on sensors maybe this will help. Its down a little bit it talks about troubleshooting temp gauges.Follow the link in this post.
http://67-72chevytrucks.com/vboard/s...9&postcount=23
That orange wire looks similer in size to the orange one on mine that goes down tward the tranny. I believe it might be for the reverse light switch. I could be wrong, mine is a 79 with a manual tranny and it's to low to crawl under and look.
Old 07-01-2008, 09:49 PM   #15
PhilaTruck
Right on the line, baby!
PhilaTruck's Avatar
The oil pressure sensor is at the back on top of the engine, behind the intake, right of the dizzy. Common leak spot.
83 GMC 406 th400/3.73 Eaton Truetrac posi, headers, x pipe, & racePros. Tubular control arms, lowering rear springs, caltracs. Still ugly, but getting built right, although slowly
Click and scroll down for site vendors!
Subscribe here!
PhilaTruck is offline   Reply With Quote
Old 07-01-2008, 10:56 PM   #16
GMBowtie79
GMBowtie79's Avatar
THats where it is on a V8 this is a 250 I6.
Old 07-02-2008, 01:40 AM   #17
hessian18
Gen III Power
hessian18's Avatar
Thanks guys for all the help....
I have not been able to find this small sensor anywhere....( checking car quest tomorrow)
Im just going to say forget it LMAO !!! The Gen III will be dropped in shortly....(hahahaha) doubt it......
I wish I had some time
---Bob---
Old 07-02-2008, 12:05 PM   #18
GMBowtie79
GMBowtie79's Avatar
Did you try disconnecting the one in the waterneck and puting the green wire on the small sensor Just to see if it works?
Old 07-19-2008, 08:29 PM   #19
hessian18
Gen III Power
hessian18's Avatar
I have tryed both....
The smaller sensor is the one I cant find anywhere.....
All the truck books and parts stores are showing the bigger temp switch in the water neck.......For my year truck and make...
I did trace BOTH this green wire and orange wire back to the oil pressure switch.....so the orange wire has to do with the oil pressure switch and so does this green wire-coolant sensor......
I cant find anywhere within the length of the orange wire to hook it up....LOL
I just want my choke light off LOL
Any body have the 81 light duty service manual ??
---Bob---
Old 11-19-2008, 11:24 PM   #20
hessian18
Gen III Power
hessian18's Avatar
Well my choke works perfectly, since its getting colder now.... I figured it wouldnt work at all since the light is on.....
Strange....I still havent figured it out
Shouldnt be to much longer until the swap is started....
---Bob---
Old 11-25-2008, 07:14 PM   #21
hessian18
Gen III Power
hessian18's Avatar
Any other input on this ??
Bobby
---Bob---
Old 12-14-2008, 09:41 PM   #22
PhilaTruck
PhilaTruck's Avatar
Electric choke? Check the resistance.
Subscribe here!
