how to take cab off with one person?
What tools would i need besides some huge ass hoist to get the cab off? ive put my project on hold just because i cant get the engine and cab off which is stupid, so i need to get this stuff off. i have an engine mount but as for the cab i dunno what to do with it even
Re: how to take cab off with one person?
Search For "Cab Lift". Look for post by ROKCRLN. He has plans for a cab and bed lift.
I used a forklift and a couple slings, but my glass was all out
Engine lifter, and some chain to seat belt/cab mount holes from memory.
1972 K2500 Long Box 400/350 |
![]() Join Date: Aug 2006
In my opinion the easiest way is the cab lift from Rockrln. I use it all the time and it is a piece of cake. You do need a cherry picker though.
Josh
(Project truck) 1970 C10 under complete transformation ![]() My current build thread http://67-72chevytrucks.com/vboard/s...d.php?t=212871 Other project: C5 corvette swap into 70 c10 http://67-72chevytrucks.com/vboard/s...=1#post2413517 On Hold |
![]() ![]() Join Date: Jul 2002
Cherry picker, some 2x4s and straps.
Bill 1970 Chevy Custom/10 LWB Fleetside 2010 Toyota Tacoma PreRunner SR5 Double Cab - DD Member of Louisiana Classic Truck Club (LCTC) Bill's Gallery Life isn't tied with a bow, but it's still a gift. Live simply. Love generously. Care deeply. Speak kindly. Leave the rest to God! Last edited by Palf70Step; 06-29-2008 at 08:24 AM. |
Resident of Here
8 rednecks who can lift good.
~Bradley~ 2004 Black GTO LS2/T56 too much to list ![]() Miss having a truck ![]() |
using the engine crane is a very easy way to remove cab// it's possible to do with a floor jack and a bunch of wood blocks too
the whole key to removing the cab or any heavy object is a basic understanding of leverage and an ability to outthink the piece needing to be removed
How big are you????
1969 4x4 Nothing beats a good rock drill and some dynamite |
see if ihad my engine out i could try to jack it up and set it on jackstands and kind of roll the frame out from underneath but the **** is in the way. how much do those cherry pickers run?
All I did was drill a hole in the middle of an eight foot 2x4. Attach the 2x4 to the bolt on the Cherry picker end, center bolt in cab with 2x4 to the front of the cab, LIFT!
Alex 1971 Lil' Red 350 SBC 700R4 Last edited by ChevyDude; 06-29-2008 at 10:55 AM. |
how much does that cab weigh out of curiosity?
#13 |
totaly stripped about 200 but its awkward,
#14 |
oh awesome then, i guess that cherry picker/engine crane will have to do. is $340 a good price for one of those? its a 2 ton one.
#15 | |
![]() Join Date: Feb 2008
The following link has some info on it with picture. http://www.bencostuff.com/products/j...Engine%20Crane I would also suggest the cab and lift that others have recommended. I used it on my truck and I thought it worked great. Took the cab and bed off by myself, easy. He also has plans for a tip/flip dolly that are in his sig. I purchased those as well and can highly recommend. Makes it nice to be able to roll around the cab all over the garage, in the driveway, etc. Here's a link to the cab/bed lift post. http://67-72chevytrucks.com/vboard/s...d.php?t=219353 And a pic with the cab lift and dolly.
1967 Chevy SWB 1972 Chevy SWB 1972 Chevy SWB K20 4x4 1991 Ford F-150 2013 Dodge Ram 1500 4x4 |
#16 |
i dont think i have enough left of my cab to frame supports to put that tip dolly on haha
#17 |
Rolled on Paint Club
![]() Join Date: Jan 2006
Some chains and a joist:
1970 GMC 1500 swb fleetside SB 355ci. Smog heads Summit 1102 cam Performer intake and carb. Finally in about 1 piece in the yard. |
#18 |
Junior Member
![]() Join Date: Mar 2007
A come-along & the rafters of the garage...
frontstreetcycle on Instagram |
#19 |
![]() Join Date: Apr 2008
Tractor supply has them for around $150 that fold up when not in use.I have sometimes seen them at Sams club but not always.
#20 |
I rolled the truck out in the grass and pushed the cab to one side slowly until it teetered. I lifted it slowly and it slid off into the grass. It only fell about 6 inches until it hit the grass. Then I just stood it up on its side. I had to replace the corners and rockers so I wasn't worried about damaging them when it hit. It was a little harder to get back on but I did it the same way in reverse. By the way I had the whole cab completely stripped of glass,doors, etc. It was just a shell.
#21 | |
#22 |
The! only way
#23 |
good ideas guys... Im going to try Bob D's method after painting.
#24 |
Restoring a 68 SWB
There you go. What garage rafters can't support 200lbs?
My Build Thread: Lucy - My 1968 SWB - Shop Truck Style North Nashville Concrete Contractor |
#25 |
![]() Join Date: Jul 2007
One in my build thread below
Chuck 68 ![]() ![]() http://67-72chevytrucks.com/vboard/s...d.php?t=374892 My trailer redo http://67-72chevytrucks.com/vboard/s...69#post5893869 Chuy my 59 bug http://67-72chevytrucks.com/vboard/s...d.php?t=653798 Putnam 87 GMC Shop truck http://67-72chevytrucks.com/vboard/s...d.php?t=707687 |
