Old 06-29-2008, 01:54 AM   #1
signguy
what's a cab wiegh
Hi does anybody have an idea what the wieght of cab without the doors is?
I want to lift it off the frame and want to do it safely, I have a big block and tackle but need to buy some rope.
signguy is offline   Reply With Quote
Old 06-29-2008, 02:03 AM   #2
PrerunnerRob
PrerunnerRob's Avatar
Re: what's a cab wiegh
I'd say in the neighborhood of 300-400 lbs
PrerunnerRob is offline   Reply With Quote
Old 06-29-2008, 08:06 AM   #3
jonzcustomshop
1961 crewcab
jonzcustomshop's Avatar
safest way, find 3-4 guys to help, that way you don't drop it... I had to wait a few days, but I found some guys that came through.
I think without the glass even as little as 3 total could lift it.
Old 06-29-2008, 12:25 PM   #4
joe231
joe231's Avatar
they are F'n heavy!!! just ask my little toe got me just behind my steel toes
there are some guys on here who have made lifting jigs to use with a cherry picker
do a search for "one man cab lift"
CHEVY ONLY
Old 06-29-2008, 02:22 PM   #5
ClassicAutoResto
Rust Buster
ClassicAutoResto's Avatar
I made this for taking off cabs and beds. Cost me about 75.00 with the wheels. I bought the steel at the steel yard in the seconds section for .15 cents a pound. Spent about 6 hours building it. We now have a 2ton chainfall on it, and NO MORE LIFTING FOR ME!!!!
ClassicAutoResto is offline   Reply With Quote
Old 06-29-2008, 03:11 PM   #6
harbourmicah
harbourmicah's Avatar
four guys can do it no problem and three probably could also. i wouldnt advise using a lift becuase it is easy to damage it that way
1966 chevy short step- under construction
http://www.fquick.com/harbourmicah
harbourmicah is offline   Reply With Quote
Old 06-29-2008, 08:56 PM   #7
scotts62
One day...
scotts62's Avatar
ya ill have to agree with you there! Sorry about that Joe.
Scott
93 crew cab build
Project 62
Old 06-29-2008, 09:00 PM   #8
joe231
joe231's Avatar
no problem, glad i could sacrifice my toe to help out
CHEVY ONLY
Old 06-29-2008, 09:04 PM   #9
scotts62
One day...
scotts62's Avatar
Im hopefully making cab mounts this week, have to move cab again.. you busy
Scott
93 crew cab build
Project 62
Old 06-29-2008, 11:00 PM   #10
ClassicAutoResto
Rust Buster
I will have to disagree.....I have pulled about 10 beds and 3 cabs since building this with NO damage to any. I use the chainfall, but with 3 inch wide nylon towstraps in an X pattern hooking the chainfall at the X to prevent any damage. Jerry
Old 06-30-2008, 12:03 AM   #11
joe231
joe231's Avatar
yeah man, when ever you are ready
where do you run the straps, under the cab, or under the top?
i pulled a cab years ago using a A-frame with a landscaping timber through the window openings and attached strap around the timber on each side then attached to a come-a-long to the A-frame. i left the doors on and the seat and every thing else in it. worked well. i was swapping it from a lwb to a swb frame.
CHEVY ONLY
Old 06-30-2008, 07:33 AM   #12
scotts62
One day...
scotts62's Avatar
Yep i used a 2x6 and cut it so it sat between the nylon strap and the cab between the doors, and then ran one through the the back and front windows up to hoist. And it made life a lil easier to use a smaller ratchet strap from the hoist to somewhere on the firewall bc the cabs are nose heavy, that way it lifts up or goes down with a lil more control. Works good if you are by yourself also
We should have had that huh Joe, maybe your little toemie would of been ok
Scott
93 crew cab build
Project 62
Old 06-30-2008, 08:50 AM   #13
joe231
joe231's Avatar
CHEVY ONLY
Old 06-30-2008, 11:16 PM   #14
ClassicAutoResto
Rust Buster
I have run the straps around the pillars in an X pattern. Glass was out on all 3 cabs. For beds, I use the rubber grommet eyebolt bed holdowns in the stake pockets, adjust them tight and attach some 2 inch straps in an X pattern to the eyebolts. I have had good luck with this method as well. The 4X4's would work good witha cab with glass, I'll keep it in mind. Usually if I am going that far with a customer's the glass comes out early. Jerry
Old 06-30-2008, 11:33 PM   #15
joe231
joe231's Avatar
cool, thanks for the info
CHEVY ONLY
Old 07-01-2008, 09:13 AM   #16
Shorty Cox
The cab will weigh considerablly more than a henweigh.
Shorty
Shorty Cox is offline   Reply With Quote
Old 07-01-2008, 01:31 PM   #17
SIR
SIR
SIR's Avatar
...15CENTS A POUND!!! aahhh the good o'l days. something like this could come in handy for your clean up and you can move it out of the way when needed..(I didn't build this) just thought it was cool....
66long low fleet http://community.webshots.com/user/LVNR66
SIR is offline   Reply With Quote
Old 07-01-2008, 01:37 PM   #18
joe231
joe231's Avatar
Shorty
I might regret this.......but,
What's a henweigh?
(a little less than a rooster??)
I need to build me one of those!! very nice
anyone in the okc area have a cab off the frame laying around, so I could mock one up?
no Scott yours won't work...wrong year
we should build one for the 60-62's also
CHEVY ONLY
Old 07-01-2008, 02:06 PM   #19
jchav62
1962 C-10
jchav62's Avatar
My bro-in-law built himself a cab remover/replacer. In the pic it's using ratchet strap tie-downs, but it was originally made to use with come-alongs...which have since broke... scary, but it works...
Joseph Chavez
"See the USA in a Chevrolet!!"
......................_____
.........________//__{\_____
,,,,,,,/__(O)___//___/__(O)_/
1962 C10 Shortbed Fleetside 327/th350 GV overdrive
1974 C10 Longbed Fleetside 350/th350 "The Trash Truck"
1999 Chevy 2500 OBS, Longbed 5.7/4L80E 4x4
2015 GMC Sierra SLE 1500 4x4
jchav62 is offline   Reply With Quote
Old 07-01-2008, 05:32 PM   #20
scotts62
One day...
scotts62's Avatar
What's a henweigh?
Lets make it! I need one
Oh ya and Joe a hen weighs about 4 or 5 lbs
Scott
93 crew cab build
Project 62
Old 07-01-2008, 05:49 PM   #21
TimE
Hey Y'all!!
TimE's Avatar
Y'all ain't right!
TimE is offline   Reply With Quote
Old 07-01-2008, 05:56 PM   #22
ClassicAutoResto
Rust Buster
[FONT="Comic Sans MS"][SIZE="4"][B][I]...15CENTS A POUND!!! aahhh the good o'l days. something like this could come in handy for your clean up and you can move it out of the way when needed..(I didn't build this) just thought it was cool....
These ARE the good o'l days. Bought some last week there....STILL 15 cents a pound in the seconds area. Alot has been cleaned out, but the price is still the same. Jerry
Old 07-01-2008, 06:28 PM   #23
joe231
joe231's Avatar
it is $0.30 a pound at the scrap yard here
CHEVY ONLY
Old 07-01-2008, 08:57 PM   #24
Ham-er
Shorty
I have no idea what a Cabweigh is!
Ham-er is offline   Reply With Quote
