PROJECT 7DEUCE
![]() Join Date: Dec 2002
Gas pedal question....
What set-up did you guys use for you gas pedal? Right now mine is mounted way up on the fire wall and makes it difficult to drive so i ordered a eliminator pedal and cable assembly was just wondering if anyone else has this set-up?
GO BIG GREEN ![]() MEMBER #6377 72 k-5 daily driver 6'' lift 35'' 350-350-205 slowly getting rust free. Project "7DEUCE" check out my build http://67-72chevytrucks.com/vboard/s...d.php?t=267665 Tim Powell..R.I.P EastSideLowlife..... R.I.P.. |
Re: Gas pedal question....
I used the lokar with the cable linkage kit................
Check out Chevy Duty, they had a stock one for V8,for the 5-6-7 truck and inexpensive
53 TuTone Extended Cab 350 4-Spd 3:08 (SOLD) 53 Chevy Moldy pearl green ZZ-4 4L60E 9" 3:25 55 GMC 1st Black Mll (ZZ4) ZZ6 TKO 600 5 sp 3:73 62 Solidaxle Corvette Roman Red (327 340hp 4spd 3:36) C4 & C5 suspension tube chassis LS 3 4L70E 65 Corvette Coupe 327 350hp 4spd 4:11 78 Black Silverado SWB (350/350) 5.3 & 4L60E 3:42 2000 S-Type 3.0 (wife cruiser) 2003 GMC SCSB 5.3 4L60E 3:42 |
Hello prostreeter 58
If you would show us a picture of the brake pedal and master cylinder set upand any info you r truck looks good and I like the view from the top of the brake setup Gene Sharp |
PROJECT 7DEUCE
Very nice thansk... Thats what I was looking for..
