Old 06-29-2008, 10:56 AM   #1
energiesource
71 bumper with 67-68 front?
I'm going for a clean(er) look and I have a 71 bumper laying around and was wondering if i could use that bumper instead of the 67-68 bumper, or would it not fit right? id rather have the signals in the bumper than the grille.
energiesource is offline   Reply With Quote
Old 06-29-2008, 03:22 PM   #2
Dingfodgy
Lemme show you something!!
Dingfodgy's Avatar
Re: 71 bumper with 67-68 front?
Yes, you can use that bumper- a couple guys around here have the same setup. It looks great BTW. The only thing I would suggest is to find another top grill insert (without the reliefs for the lights) and swap it out for the bottom one.
'67 CST-10 LWB ("Crusty") SOLD
'67 GMC SWB ("Murdock")
2000 K1500 Suburban ("Betty")
'95 BMW 325i ("Joy")
Dingfodgy is offline   Reply With Quote
Old 06-29-2008, 04:32 PM   #3
energiesource
do they actually make the grill supports without them? or would i need to cut them and all that?
Old 06-29-2008, 08:32 PM   #4
oldgold70c10
Who's got steelies?
oldgold70c10's Avatar
No, he is talking about the pieces that are pop-riveted to the back side of the openings along the bottom; the part that makes the grill look thick, and not just a piece of sheetmetal. The one for the bottom opening has a relief and holes for mounting the signal/direction lights. Since they are the same otherwise, get another top one and rivet it in place of the lower one to complete your cleaner look.
1969 C10 LWB W/ 250 I6 & 3spd
1970 C10 with '67 small window cab, 68 front end, blue; 305/TH350, 3.08 limited slip rear end, manual brakes, power steering; & 4-wheel drums-My daily driver.
1975 Chevelle Malibu Classic Coupe 350/th350 mint green
1970 C20 Suburban 350/700R4 4.10 gearing green & white
1978 Big 10 Silverado 350/th350, working ac, 2 tone blue-My summer daily driver
1983 GMC 1500 Sierra 305/SM465 2.73 rear end
How to add a trip odometer to your 67-72 stock speedometer
How to rebuild your Q-Jet
My Truck Page
My Youtube Channel
oldgold70c10 is offline   Reply With Quote
Old 06-29-2008, 10:35 PM   #5
dieselarmy13
Phone's ringin Dude.
dieselarmy13's Avatar
someone stop me if i'm wrong, but i'm pretty sure you will need different outer bumper brackets as well.
I pitty the fool with only two headlights!!
2003 SILVERADO SS--THE NEW GIRL
1972 GMC--THE OLD GIRL
dieselarmy13 is offline   Reply With Quote
Old 06-30-2008, 05:36 AM   #6
You are correct sire. The outer brackets need tobe longer to clear the spot for the turn signal light openings.
Old 07-03-2008, 05:55 PM   #7
chevy_mike
Never Ending Projects
chevy_mike's Avatar
I was hoping someone would have pictures of this combo done.
Does anyone???
1965 C10 Panel, Tiki Express http://www.67-72chevytrucks.com/vboa...d.php?t=506580 SOLD
1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD
1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD
We were given two ears and one mouth for a reason... listen twice as much and speak half as often...
chevy_mike is offline   Reply With Quote
Old 07-03-2008, 06:51 PM   #8
john
member #16
john's Avatar
Thats what I did. They dont show in the pic, but replaced the lower bar with another upper one had had them chromed.
john is offline   Reply With Quote
Old 07-03-2008, 07:21 PM   #9
chevy_mike
chevy_mike's Avatar
Nice truck! I was checking out your build pics too, very cool.
As for the bumper, hum... I am out on if I like it better or not. Nothing wrong with what you did, just not used to seeing the lights in the bumper on '67/68's.
Old 07-04-2008, 02:09 PM   #10
clay68c10
clay68c10's Avatar
I pulled the signals from my grille and used signals in my headlights, plus hooked up the front sidemarkers to flash as well. I used the H4 lights with the single 194 LED bulb. To do it again, I'd pony up the $$ and get these:
http://www.yogisinc.com/Detail.cfm/-...77/product.htm
ClusterTruck: 68 C10 Bought in 89, wrecked in 03. Slow low $ rebuild started '17. 6.0 & TKO
http://67-72chevytrucks.com/vboard/s...d.php?t=788602
93 K1500 Short Step, 350, NV4500, EBL flash ECU. Vortec heads & roller cam someday...
05 Jeep Wrangler Unlimited. 3” lift & 6-speed
02 E320 the insurance total “free car”
13 Tahoe LTZ
clay68c10 is offline   Reply With Quote
Old 07-04-2008, 03:26 PM   #11
jorgensensc
jorgensensc's Avatar
GOt a pic? THis is what I am planning on doing also. I Already have the headlights.
Shawn
1972 C20 Suburban- Big Blue Betty
'56 Chevy Bel Air Sedan- Frame up Restoration
-What would you attempt to achieve if you knew you could not fail?-
-I Refuse To Tiptoe Through Life, Only To Arrive Safely At Death's Door-
R.I.P. EAST SIDE LOW LIFE
jorgensensc is offline   Reply With Quote
Old 07-05-2008, 01:58 AM   #12
clay68c10
clay68c10's Avatar
Here ya go
13 Tahoe LTZ
Old 07-05-2008, 07:48 AM   #13
LUV2XCLR8
The LuvShack Garage
LUV2XCLR8's Avatar
Nice look
Owner/Op: "TN Classic Transport Carriers"
The Toy: "Square Vette" 72 Hybrid Blazer
Toy Barn: "LuvShack" 40 x 60 x 20 Shop
Tow Piggy:"Maddy" 88 Silverado 3500
Hauler: "Feathers" 14 Aluma 8218T
LUV2XCLR8 is offline   Reply With Quote
