06-29-2008, 03:15 PM | #1 |
Junior Member
Lowering blocks on 67-72 trucks (coil spring truck)
What are lowering blocks?? PICS and info please..(how they work). I have read more than a fe threads that mention to use lowering blocks....but no pics. Sorry for the stupid question.
going to sell this one...looking for a SWB project next. |
06-29-2008, 03:20 PM | #2 |
Junior Member
Re: Lowering blocks on 67-72 trucks (coil spring truck)
A block that goes in between the trailing arm & the rear end. essentially raises the rear end into the truck body...lowering the vehicle...
frontstreetcycle on Instagram |
06-29-2008, 03:49 PM | #3 |
This isn't the coil spring set up but maybe you'll get the idea. This are on my S10. 3" lowering blocks.
*We could learn a lot from crayons... Some are sharp; some are pretty;and some are dull. Some have weird names; and all are different colours;but they all have to live in the same box. * You may be only one person in the world, But you may also be the world to one person. * Some mistakes are too much fun to only make once. Two rules in life. 1. Never sweat the small stuff! 2. Everything is small stuff! |
07-07-2008, 11:32 AM | #4 |
Its Topless Season!!!!
Here is a sticky in case you want to make your own http://67-72chevytrucks.com/vboard/s...d.php?t=196457
07-07-2008, 12:19 PM | #5 |
They come in a kit with new U bolts. They go between the arms & axle. I put 2" on my 70 stepside & didn't like them. They caused vibrations & it didn't drive as good. I took them off.
07-07-2008, 01:29 PM | #6 |
lowering blocks caused vibrations? never heard that one before ...
07-07-2008, 02:23 PM | #7 |
x2.
07-07-2008, 03:23 PM | #8 | |
Nothing to see here.....
nice to know people with a cnc!
Doug THANK YOU to our American Soldiers & Veterans - POW MIA "You will NEVER be forgotten". The democracy will cease to exist when you take away from those who are willing to work and give to those who would not. Thomas Jefferson |
07-07-2008, 03:38 PM | #9 | ||
I supposed that it is theoretically possible to change the pinion angle enough to cause a vibration.........but I don't see how it could change how it drives? |
07-07-2008, 07:00 PM | #10 |
I wish I was a cowboy
Speaking on blocks and pinion angles and vibrations, if the pinion angle is, say, 1 degree off, will this cause these dreaded vibrations? In lowering my truck, I'll be changing the angle at the tailshaft, so want to change it at the rearend accordingly...
-Kris Met list: Cyclone,Wilson,TranzAm,extd56,hotrodhomi,mnky30,Rokcrln,Brad,JerryJones(well, his truck anyway). |
07-07-2008, 11:47 PM | #11 |
I've done several swb coil suspension trucks w/lowering blocks & experienced no vibrations afterward. I have not done a lwb truck so I'm no help there.
