06-29-2008, 03:36 PM | #1 |
Which S10 frame can you use??
I have been offered a 51 Cherolet 3100 truck. It is a 3/4 ton now, but if I bought it I would want to do the S10 frame swap so I'll have all the modern brakes and etc. The truck has no bed, so basically it is just the cab and front clip. Did they have different bed sizes in 51.
I have access to a 94 longbed S10. Would I have to shorten or lengthen the frame to make it work?? Any info would be appreciated.
*We could learn a lot from crayons... Some are sharp; some are pretty;and some are dull. Some have weird names; and all are different colours;but they all have to live in the same box. * You may be only one person in the world, But you may also be the world to one person. * Some mistakes are too much fun to only make once. Two rules in life. 1. Never sweat the small stuff! 2. Everything is small stuff! |
06-29-2008, 09:58 PM | #2 |
Re: Which S10 frame can you use??
i used a 98
06-29-2008, 10:19 PM | #3 |
Looks like a nice project, But which frame length did you use?
06-29-2008, 10:57 PM | #4 |
any s10 standatd cab long bed frame will work to fit your cab and 6foot box. for more info you can try these sites www.e-zchassisswap.com or www.ad-engineering.com good luck or your swap
There is nothing you can't fix with a BFH or a FIRE WRENCH. 1997 chevy k1500 ext cab z71 (daily driver) sold 1996 chevy k1500 reg cab 4x4(daily driver)totaled 2008jeep patriot (wife's daily driver 2008 chevy 1500 ext cab 4x4 sold 2011 chevy 1500 crew cab ltz (daily driver) 1996 chevy 1500 reg cab 4x4 project sold 2006 pontiac grand prix gxp (daily work commuter) |
06-30-2008, 04:46 PM | #5 |
my 47 truck is a long bed i used a 98 extended cab the wheel base was only 3/4" to short so i moved the rear fenders.
06-30-2008, 06:26 PM | #6 |
Hey gr8one, Did you buy a cab mounting kit or did you fab your own mounts ??
06-30-2008, 06:59 PM | #7 |
i fabbed my own the body is 2" off the frame. lowered and moved back the rear fender.
07-01-2008, 09:22 PM | #8 |
Do you have any during photo's?
07-02-2008, 09:55 AM | #9 |
If all you are working with is the cab and front clip off of the '51, then you can choose to keep it a 3/4 ton by using the s10 extended cab frame (122"). Or you can use a 1/2 ton bed, and go with the s10 regular cab long bed (117"). I'm keeping my as a 1/2 ton. The issue I ran into was the radiator core support. Short of building your own custom core support, your cab will have to be atleast 5 to 6 inches off the frame. I'm sure there is a way to get around this, but not without a lot of frabrication. Also, if you choose to go lower, a hump for the tranny comes into play.
07-02-2008, 06:22 PM | #10 |
Thanks, Jeff. If I decide to tackle this job. I will be going with the shorter of the the two. Thats good though since The S10 I have is a regular cab longbed.
