06-29-2008, 03:58 PM | #1 |
Georgia Boy
TH350 or 350C?
My truck originally came with a 350C.. and I was thinking that with todays gas prices the way they are, it might get a little better MPG with the overdrive. With the 350 in my truck now(.030 over, Edelbrock cam, intake, flattops and long tube headers), I was wondering if it's possible, or feasible to build a TH350C to handle the power(and future power) this engine will make.. or just stick with the TH350 in it and just deal with it without the overdrive?
06-29-2008, 06:52 PM | #2 |
BAD BOW-Silverado XST
Re: TH350 or 350C?
Swap the converter. You don't need an electronic TH350C to lock a converter. You can add an aftermarket stall converter. Depending on power, lock it below cruising speed RPM. A stock or slightly modified engine should have a range of 1800-2000 RPMs. I had one on my old 305. Worked great. You can find decent torque converters for about $150 and up.
Welcome to the site. |
06-29-2008, 07:13 PM | #3 | |
Georgia Boy
Re: TH350 or 350C?
So I can throw in a converter and make it act like an overdrive? Or can I performance build a 350C and it'll be tough enough to take the 500+ hp I will have under the hood? |
