Old 06-29-2008, 05:04 PM   #1
mateo1279
mateo1279's Avatar
Cleaning/adjusting while intake is off...
Finally have all the parts to complete my intake/carb/valve cover swap... should be doin' it on the 8th-9th.
While I have the valve covers and intake off are there any adjusments, tuning, or cleaning I should do or be prepared to do? I am mainly thinking in terms of the vavle train, but I might be over looking something....
Motor: Bone stock 283 in my 62 chevy.
Stock intake manifold - Holley duel plane
Stock 2bbl carb - Holley 4160 4bbl
Stock covers - new covers with breather/pcv provisions
Thanks All!
-Matt
1962 Chevy Fleetside
283/TH350
mateo1279 is offline   Reply With Quote
Old 06-29-2008, 08:48 PM   #2
Ham-er
Re: Cleaning/adjusting while intake is off...
Flip the intake upside-down while it is off the engine. If it has one of those tin plate covers over the center carb-warming section. remove the cover and clean all the carbon out of there. Holley intakes might not have this feature.
The stock GM intakes on v8 engines are famous for carbon buildup in this spot.
Ham-er is offline   Reply With Quote
Old 06-29-2008, 10:07 PM   #3
ChiefRocka
Hollister, CA.
ChiefRocka's Avatar
Pull the pushrods/lifters and change out the cam, mabey ??
That would give you some "tuning" !!
John
What the Heck is that ??
CURRENT BUILDS:
62 BurbMaster
Other Builds:
My '63 C-10,LWB,CC,BBW
'06 HD StrAight Axle Swap
Father/Son '67 C-20, LQ9,4L80,Bagged,8-Lugger !!Good Friend Richard's Build
AMERICAN CUSTOMS & CLASSICS (831) 630-1965
www.ACCHOLLISTER.com
ACC on FACEBOOK
"Rest in Peace, Mom & Dad ... I will see you again someday!"
ChiefRocka is offline   Reply With Quote
Old 06-29-2008, 10:27 PM   #4
billydonn
Council of the Elders
billydonn's Avatar
Just wipe up any residual goop, maybe double check the oil pressure sender fitting for tightness... there's not much to do really. Remember to mark the position of your distributor so you can put it back and not screw up your timing.
I would in fact do some wiping up before you take off the intake!
66 C-10 Stepside
350 Tuned Port Injection
Tremec TKO-600
Truck Pictures: http://community.webshots.com/user/billydonn
Truck Video: http://good-times.webshots.com/video...ost=good-times
billydonn is offline   Reply With Quote
Old 06-29-2008, 10:49 PM   #5
scotts62
One day...
scotts62's Avatar
even take a quick trip to the car wash if it runs and spray her down
Scott
93 crew cab build
Project 62
Old 06-30-2008, 11:50 AM   #6
mateo1279
mateo1279's Avatar
That would definatly give me some "tuning"!
That'll have to be down the road unfortunatly... I have been collecting parts for this since the beginning of the year, and finally have all the parts to finish plus some free time to do it! 1.5 days should be enough to finish this up and maybe have some time left over to finish the headlight switch/relay thing I started!
283/TH350
Old 06-30-2008, 11:51 AM   #7
mateo1279
mateo1279's Avatar
I have a decent pressure washer... what protection needs to be done to blast the engine bay with everything in it?
283/TH350
Old 06-30-2008, 02:03 PM   #8
64Magoo
Simply take the front end and cab off of the frame, which should protect the firewall and inner fenders from harm, spray the engine, a voila! Clean engine. Very very simple and should take about as long as it would to wrap your alternator with a plastic bag.
64Magoo is offline   Reply With Quote
Old 06-30-2008, 07:49 PM   #9
pquick
pquick's Avatar
aaahhhhhhhh,
pquick is offline   Reply With Quote
Old 07-01-2008, 01:04 AM   #10
mateo1279
mateo1279's Avatar
Nice! I sure dropped some serious dough on the paint for my firewall. Fading primer on the body, uber custom on the firewall. I have always thought that it is more important to be beautiful on the inside...
283/TH350
