Old 06-29-2008, 10:28 PM   #1
Bowtiefreak
Bowtiefreak's Avatar
Tie rod/ Center link pics needed
Hey Everyone,
Can I get someone to post a picture or two of the proper tie rod and center link position on a 2 wheel drive.
Also, which tie rod is the inner and outer.
Thanks a million!
1968 Chevy C10 Short Fleetside/Wood floor
ECE 4-6 Drop / 406 Small Block
1971 Chevelle 427 Big Block
Bowtiefreak is offline   Reply With Quote
Old 06-29-2008, 11:54 PM   #2
LockDoc
The Older Generation
LockDoc's Avatar
Re: Tie rod/ Center link pics needed
Here is a couple of threads on it. I'm not sure if they are 2wd or not I didn't read them.
http://67-72chevytrucks.com/vboard/s...ht=center+link
LockDoc
Leon
Old 06-30-2008, 12:38 PM   #3
shifty
Questionable
shifty's Avatar
what year truck are we talking about here? 67-70 are drastically different than 71-72.
If I've got anything up for grabs, it'll be here: 7-hole gauge cluster for a 67-72 p/u FREE (link)
I can't check the forum daily. If I don't reply to you within 24 hours, drop me a PM! I'm (hopefully) still alive and will reply faster to a PM.
shifty is offline   Reply With Quote
Old 06-30-2008, 01:10 PM   #4
68gmsee
Active Member
68gmsee's Avatar
Here's some from my 68 GMC...
68gmsee is offline   Reply With Quote
Old 06-30-2008, 01:25 PM   #5
shifty
Questionable
shifty's Avatar
btw -
this thread may help you as far as part #'s go: http://67-72chevytrucks.com/vboard/s...d.php?t=216886
here is a gallery showing the teardown of my steering: http://satellitehead.com/gallery/thu...s.php?album=10
here is a gallery showing the cleanup phase of my project, there are some shots of steering here: http://satellitehead.com/gallery/thumbnails.php?album=4
there are probably some more photos in there somewhere, not sure if they help.
my truck is a '68.
oh, and i have a brand new '68 tie rod and center link setup, if you're interested. i ended up upgrading my truck to use a '73-'87 crossmember, so i'm not going to use my center link, tie rods or sleeve. brand new setup - name a price that's good for you if you want it.
Old 06-30-2008, 01:45 PM   #6
Bowtiefreak
Thanks for the help guys!!
Shifty
I was referring to a 69 frame.
Thanks, Ron
