Old 06-29-2008, 11:19 PM   #1
Fastrucken
Junior Member
Fastrucken's Avatar
front crossmember bracket question
How much will it lower the back if I flip the front trailing arm bracket where it attaches to the crossmember??
Reason I wondering is I need it to be about an inch lower so I can run with alittle more air in my rear bags. It should give me a better ride. Im only running like 20-25lbs right now and I think I'm hitting the bump stops in my bags now. I'm trying to do this on the cheap but will buy some blocks for the rear end if need be.
Graham
A good friend will come bail you out of jail, but a true friend will be sitting next to you saying, "That was ****ing awesome."
Fastrucken is offline   Reply With Quote
Old 06-29-2008, 11:51 PM   #2
poorboy
poorboy's Avatar
Re: front crossmember bracket question
I don't think it would lower it very much. I think it would change the pinion angle more than anything.
63 short fleet Patina build
http://67-72chevytrucks.com/vboard/s...d.php?t=287751 Man I want another one.
poorboy is offline   Reply With Quote
Old 06-30-2008, 12:07 AM   #3
joe231
joe231's Avatar
wouldn't lower it any
CHEVY ONLY
