Old 06-30-2008, 12:14 AM   #1
original_balzer
original_balzer's Avatar
will newer chevy van front suspention work on our trucks?
I have a line on a VERY clean 95 chevy van its a cargo van with a 350 and 4l60e trans. It belonged to an older gent who did electrical and locksmith work and only has 78K miles on it.
I can get it cheap enough I will buy it either way. But if I can I would swap everything to my 67. Disk brakes a-arms rear axle engine trans computer and anything else I can use.
original_balzer is offline   Reply With Quote
Old 07-02-2008, 02:57 AM   #2
original_balzer
Re: will newer chevy van front suspention work on our trucks?
nobody knows? oh well the old fart is gunna keep it and work a few more years anyway
Old 07-02-2008, 05:26 PM   #3
PanelDeland
I am a Referee of life.
PanelDeland's Avatar
A 95 will not work.Up to 87 I believe will fit.You can use the whole front crossmember and the power steering box.
BTW There are lots of posts and good info on what will work with what and which parts can be interchanged in the FAQ's section.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion.
You can't fix stupid,not even with duct tape.
"My appearance is due to the fact that "GOD" does punish you for having too much fun!"
Barrett-Jackson has perfected alchemy,they make rust into gold!
"You can lead a horse to water but you can't saddle a duck"
"Cleverly disguised as a 'Responsible Adult'
"Sometimes your Knight in shining armor is just a retard in tinfoil"
PanelDeland is offline   Reply With Quote
Old 07-02-2008, 09:39 PM   #4
DirtyLarry
Windy Corner of a Dirty Street
DirtyLarry's Avatar
1995 would have worked but since the old codger won’t let it go it doesn’t matter now. 1970 – 1996 (early 1996) full size unibody vans have common front suspension with 67-87. The 1996 and later G-vans with the full frame are a different animal. Even the stripped P-chassis (Chevrolet/GMC/Workhorse) right up to 2005 had common front suspension with the 67-87 trucks as well.
DirtyLarry is offline   Reply With Quote
