06-30-2008, 01:40 AM | #1 |
PLEASE HELP! Bagged front questions
I know, i know.. i've searched for hours tonight but havent found the answer to my question, so here goes... I'm bagging the front of the truck, standard re7's w/SD brackets, i'll be running a 255/35/20 tire ( i think 27" overall) w/2.5" ece drop spindles
I would like to know if my stock fenderwells will be too shallow for the truck to be fully aired out, and to throw a kink in this i'd like to know if i need to bother w/cutting my lower cups down to 1.5" ....if the stock fenderwells will be in the way, i really have no problem using aftermarket/trailer fenders for fenderwells, but would like to retain the stock wells if at all possible, and dont want to cut the cups down if it wont make any difference in the long run w/the tire already hitting the fender well Any pics of bagged suspension on bigger wheels or 27" tire appreciated, as is any info... thanks, hope i made this as confusing as possible
67' in the "build" process.. soon to be bagged, big wheels ect, finally got it back home!! |
06-30-2008, 03:04 AM | #2 |
3DrDwn--the 'burb not the band
Re: PLEASE HELP! Bagged front questions
it's going to hit the fenderwells. My 245/35/20s hit LONG before the air was all the way down.
Slo and Lo that is the tempo. '72 burb build page here: http://67-72chevytrucks.com/vboard/s...d.php?t=259256 '89 GMC Dually crew build page coming soon. 88 4x4 crew DD duallys past/present pics here: http://67-72chevytrucks.com/vboard/s...46#post4001246 89 1 ton Dually rear flip kit install here: http://67-72chevytrucks.com/vboard/s...d.php?t=354327 |
06-30-2008, 09:04 AM | #3 |
yeah you'll have to cut them dude. besiseds avs has some nice iners with a nice rolled lip that look bad a$$! did you do a z? also the hood hinges will be in the way aswell. it depends on the drivers side upper controll arms will also intherfear with the stock colum shaft to box.
